Old 01-07-2016, 08:40 AM   #1
Asoto32
Asoto32 is an unknown quantity at this point
Engine problems
Hello everyone I have an s14 with the KA24DE with cold starts it will take multiple cranks to start up the car and when it starts it'll idle irregularly until it levels out (levels out low at 800rpm) roughly, has anyone had this problem before I know MAFs are known to go bad on 240s
Asoto32 is offline   Reply With Quote
Old 01-07-2016, 09:39 AM   #2
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
Your IACV might be bad or clogged a little.
Is your cel on?
SoundEfx is offline   Reply With Quote
Old 01-07-2016, 09:41 AM   #3
Asoto32
It used to be for an Evap issue but I disconnected the battery like 2 months ago to splice some lights and it never came back on
Old 01-07-2016, 10:19 AM   #4
SoundEfx
SoundEfx's Avatar
Have you ever changed your coolant sensors?
If it never leveled out, I would have thought that it was a vacuum leak.
Old 01-07-2016, 10:20 AM   #5
Asoto32
Nope but I flushed the coolant when I switched out my leaky waterpump not too long ago
Old 01-07-2016, 10:30 AM   #6
SoundEfx
SoundEfx's Avatar
I had a rich idle issue with my KA-T and when I changed the coolant sensors, it helped significantly. So it's not the coolant in question because if the sensors are not reading the temperature correctly, you could still have issues.
I might start there because they are just a few dollars each.
Old 01-07-2016, 10:31 AM   #7
Asoto32
Thanks man appreciate the advice!
