Old 09-20-2004, 11:27 PM   #1
SignalAutodrifter_D
SignalAutodrifter_D's Avatar
SignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura aboutSignalAutodrifter_D has a spectacular aura about
another prob..car runs great...but dies out of no where???
i finally got my 240 running and she is beautiful....i had her for about 2 days running...then turbo blew...got a T28 on the next day and was off again..2 days later..i took it to wisconsin to watch drag racing and also wanted to put some miles on the new motor and clutch....after i got back....the very next day..drove the car and it died on me while i was driving. i didnt think any thing of it so i turned the key and it started right back up.....
went to school..then when i got out i drove it to try to leave the parking lot and it died....i waited about 3 mins then it started again....drove it for awhile then went home....after that i tried to go some where else.and bam...it dies on me in the intersection where everyone was at...so that was koo...but this time it died for almost 10 mins...
i got it going again and then its been runin on and off til i got home to park it....but i dont know where that is from??i check the battery, the wires in the front....i checked out alot and i dont know how something like this can hapen so its going to be parked again for alil while cause i been bz....help me out guys!!
i was goin to redo my timing again...
SignalAutodrifter_D is offline   Reply With Quote
Old 09-21-2004, 12:59 AM   #2
idlafie
idlafie's Avatar
Check for a loose wires at the connections. It may meter okay with a multi-meter, but when you wiggle the wires at the connector, the wire will cut out. Easiest way to find the loose wire is to start the engine & let it run while you wiggle the wires. Just be VERY careful not to get your hand caught in the fan blades, belts or pulleys.
Hope this helps....
ID
Old 09-21-2004, 07:17 AM   #3
SignalAutodrifter_D
which connectors am i going for...well i thought it mite be some connections..but yesterday i had the car on and i was just watching it and jus dies slowly......is there anychance it can be motor problems..?? well im going to continue looking for lose wires and im going to sauter all the wires instead of the electrical tape...
Old 09-21-2004, 07:46 AM   #4
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
I was going to say check the mafs. I had an altima that did that. It ran perfectly and would just stall out for no reason. Replaced the MAFS, problem solved.
-Retired
98s14inaz is offline   Reply With Quote
Old 09-21-2004, 11:00 PM   #5
SignalAutodrifter_D
well tomorow im going to sauter all my connections and clean everything up.. make sure everything is tight and secure...so ill let you guyess know whats up..
Old 09-24-2004, 10:45 PM   #6
90sr
90sr is an unknown quantity at this point
yah dude i had the same issues when i first got my sr running, id get on it a little bit and it would just die out, i messed around with the iacv (idle air control valve) and the little idle adjustment screw, tightened my vacuume lines, done never stalled out again.
chris
chris's sr
90sr is offline   Reply With Quote
