Old 03-07-2002, 01:42 PM   #1
Ni5mo180SX
Ni5mo180SX is an unknown quantity at this point
Send a message via AIM to Ni5mo180SX
Yea my car went over 135 with no governer kicking in. My friends S14 hit 120 with no problems from a limiter.
Mazda RX-7 FC3S: Jspec motor, ported turbo & wastegate, JIC FLT-A2 coilovers, Mazdatrix adj. rear camber link, TB mod, Koyo 53mm Radiator, Corksport Cat back/midpipe/downipe, 3" Al TID, Apex'i air cleaner, Mazda Comp. mission/motor/differential mounts, Mazdaspeed Strut Bar(R), FD torsen differential, HKS SSQV, HKS elec. boost gauge & elec water temp, Cusco Oil catch, 680cc secondary's, Walbro 255, Banzai Racing FCD, RB DTSS Eliminator bushings, Exedy Clutch & PP, Exedy chrome moly flywheel, RB oil baffle, RB dual alt. pulley, 5 lug conversion, FC3S.org thermal bypass pellet, KVR Cross drilled rotors, complete Energy PU bushings, stainless steel brake lines/clutch line, Aerodyne shroud panel, Azenis RS, and some other stuff. A hybrid of sorts I guess
Ni5mo180SX is offline   Reply With Quote
Old 03-06-2002, 06:42 PM   #2
YellwMonky
YellwMonky's Avatar
YellwMonky is an unknown quantity at this point
I've recently learned that in order to remove your speed governor all you need to do is cut the yellow wire from your wire harness....now i'm about to do this but i want to know if anyone else has done this. I've heard that all it does is remove your speed governor but if so why hasn't everybody done this ? Is there any problems associated with cutting this yellow wire? I can't stand this speed governor and i can't see why everyone doesn't feel the same !?
s13 92 White 240sx SE Coupe
YellwMonky is offline   Reply With Quote
Old 03-06-2002, 06:53 PM   #3
j1n102
j1n102 is an unknown quantity at this point
Send a message via ICQ to j1n102
i hear that bro! but i think ill try that after you.....hehehhe
j1n102 is offline   Reply With Quote
Old 03-06-2002, 07:18 PM   #4
s14vaxlr8
s14vaxlr8 is an unknown quantity at this point
Send a message via AIM to s14vaxlr8
cut it cut it cut it
cough cough *geinie pig* cough cough <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
96 Kouki w/sr20det for sale
http://www.zilvia.net/f/showthread.php?t=66164
s14vaxlr8 is offline   Reply With Quote
Old 03-06-2002, 10:07 PM   #5
YellwMonky
YellwMonky's Avatar
...are you guys serious? nobody has done this <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> what is wrong with you people !??!?! hahah well, i dunno bout being the guinea pig.....i really do want the speed governor gone tho...can't stand having to leave races at 110....SOMEONE ELSE DO IT AND TELL ME HOW IT WORKS!!!
Old 03-06-2002, 10:13 PM   #6
hybrid240
hybrid240's Avatar
hybrid240 is an unknown quantity at this point
here is an idea: cut it and it it screws any thing up ....put it back and hope that fixes it! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
boostin through a neighborhood near you!
hybrid240 is offline   Reply With Quote
Old 03-06-2002, 11:06 PM   #7
v8killer
v8killer is an unknown quantity at this point
I cut it- no sweat. On the 8th pin on the ECU from the right. Yellow wire with green stripe and silver dots. Kills the info. from the car to the ECU but the dash still works. (HUD)
Good Luck!
p.s. DISCONNECT BOTH TERMINALS AT THE BATTERY BEFORE STARTING THIS JOB OR YOU'LL BE SORRY!! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>
91 SE Coupe wit' all the fixins'
http://www.roadtoadspeedshops.com
v8killer is offline   Reply With Quote
Old 03-06-2002, 11:19 PM   #8
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
how bout in an s14?
burgy240 is offline   Reply With Quote
Old 03-07-2002, 12:00 AM   #9
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
I cut mine and it's still governed by a low rev-limiter in 4th and 5th. &nbsp;When you hit 6200 in 4th and 5100 in 5th, it's just like hitting 7000 in 1st, 2nd, and 3rd...the engine just goes "wa-wa-wa-wa-wa". &nbsp;I believe you have to disconnect the 4th/5th gear speed sensors in the tranny to fix this...but I haven't gotten around to trying it yet.
LanceS13 is offline   Reply With Quote
Old 03-07-2002, 01:26 AM   #10
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
Well I've heard that it triggers a check engine light, anybody look into this issue?
Grant is offline   Reply With Quote
Old 03-07-2002, 09:27 AM   #11
JDM S13
JDM S13 is an unknown quantity at this point
what about on a SR20DET?
Zenki SR20DET Red Top
JDM S13 is offline   Reply With Quote
Old 03-07-2002, 09:40 AM   #12
Guest
Posts: n/a
ive allready gone to 240+ kmh i didnt cut anything everything was stock, it seems i dont have a speed limiter or sumthing,
maybe its because my car is an automatic.
Old 03-07-2002, 11:19 AM   #13
Tyler Durdan
Tyler Durdan's Avatar
Tyler Durdan is an unknown quantity at this point
I was driving my car around last night and reached speeds of 116 and 117 mph. &nbsp;I kept expecting the gov. to kick in, but it never did. &nbsp;Does anybody know when it kicks in on a 97 240sx se?
&quot;Pure adrenaline attached to a license plate. &nbsp;Isn't it time to experience one yourself?&quot; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; -Dan Gurney
Turbo for Sale
Tyler Durdan is offline   Reply With Quote
Old 03-07-2002, 01:09 PM   #14
sykikchimp
WOW addicted
sykikchimp's Avatar
Automatics did NOT come with Speed limiters. &nbsp;ONLY rev limiters
Old 03-07-2002, 06:23 PM   #15
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
the S14 has a fuel cut a bit after 120. &nbsp;The S13 cuts at 113. &nbsp;I did the wire cut in my 1992, and had no problems afterwards. &nbsp;I've never heard of anyone trying it with an S14, which is why I haven't done it yet, although I'd like to, since a fuel cut under boost could mean a blown engine......
AceInHole is offline   Reply With Quote
Old 03-08-2002, 03:13 AM   #16
240booster
240booster is an unknown quantity at this point
search the forums for "yellow wire with green stripe" should bring up my post from a couple months ago. I gave pretty specific details on it. Ur check engine light is goin to come on cause the ECU can't read the speedometer nemore no biggy. Beware there r 2 &nbsp;yellow wire's with green stripes believe me i have already been the guinea pig. One has a single silver dot every inch or so and the one u need to cut has 2 silver dots ever inch or so. That should kill ur speed limiter at 118mph then just unplug the electrical 5th gear connection on the side of the tranny (its a rev limiter that limits u in 5th gear at about 5500rpm or 125mph). Then the sky's the limit ... i think my top speed is about 140mph. This is for an S14 i would think it would be about the same for an S13 but not making ne promises. &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
FAST [br]AND[br]FURIOUS
240booster is offline   Reply With Quote
Old 03-08-2002, 07:40 AM   #17
v8killer
See, that's weird 240booster- I didn't have that wire setup on my S13. I had two wires, one from the instrument cluster (I think that's the one you cut first) and one from the ecu (8th pin from right on ecu) which is the one I cut. My point is, I don't have a problem with codes or lights, and I didn't have the two-silver-dot-yellow-wire either...BOTH looked exactly the same, just looking closer showed me that one came from the dash, and one comes from ecu...
What's up with that??
Old 03-08-2002, 08:57 AM   #18
AceInHole
Autox Technician
AceInHole's Avatar
When I did the cut in my S13 there was no check engine light either.... I'm not willing to try it in my S14 if the check engine light is going to show (I hate warning lights when there's no warning)... so I guess I'm stuck waiting for a JWT ecu....
Old 03-08-2002, 10:52 AM   #19
YellwMonky
YellwMonky's Avatar
Well, I just cut my wire yesterday and the check engine light came on. The reason why some of you did not get the check engine light is probably because your ecus are not from california ECUs. California has to pass special emissions which force the code &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'> &nbsp;There's just one strange thing, after i cut my wire when i slow down to a stop my revs go all the way down like i'm about to stall. They jump around between 200-400 rpms until they slowly crawl back to the normal 700. This has gotten me a little worried and i'm trying to figure a way to fix it. OH yeah and 240 booster, where is the wire on the tranny to unplug so i can pass up that rev limiter. Any negative side effects from unplugging it ?
