![]() Name: Adam
Location: Greensboro, NC Phone: 336-430-6178 price: $13500 Just looking what people offer, because I can't hold onto a car until I own a Supra. Probably the best 240 I've owned. Drifts amazingly. Have had the car for about 2 months. Since getting it I have replaced: Waterpump Valve Cover gaskets Exhaust Manifold gasket (driver side) New Spark plugs Fixed headlight (one headlight worked) Fixed passenger window (wouldn't go down) 1995 Nissan 240sx Kouki Front End Fiberglass front wide body fenders Carbon Fiber Hood LED Taillights RB Wing Roof Wing Aqua marine firemist paint LS1 engine. 95K miles Slide motorsports mount kit Custom headers and 3" exhaust Canton Racing Oil Pan Melling High Volume/pressure oil pump Brand new Waterpump, valve cover gaskets, and exhaust manifold gasket (driver side) T56, new synchros ACT 6 puck unsprung clutch Custom 1 piece steel driveshaft PBM Coilovers Tein Tension rods Custom extended adjustable FLCA with 3/4 hiem joints Custom modded high angle knuckle kit PBM solid rack eccentric bushings Welded diff PBM solid subframe risers Drilled/Slotted rotors Custom dual rear caliper set up Hydro Brake Full tube front (NOT FD Legal) Front and rear bash bars Full cage Fully stripped interior Power Windows (both go down) Digital gauges (oil pressure, water temp, oil temp, fuel level, tach) Battery kill switch Bride Rep racing seats Brand new Buddy Club rails (driver side only) Takata racing harness Plastic 14 gallon fuel cell Walbro 255lph Adjustable fuel pressure regulator Aluminum dual core radiator 2 - 12" electric fans Power Steering cooler Braided high pressure steering line D1 spec overflow bottle No AC No heat No windshield wipers No turn signals (will be fixing soon) ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by supra97; 09-08-2016 at 12:44 PM.. |
