Old 10-23-2016, 05:27 PM   #1
couped89
couped89's Avatar
couped89 is an unknown quantity at this point
s13 Sr20 redtop wont fire, no spark etc.
Just swapped in my sr and im not getting any spark. I've checked all my grounds and they are all good. I've checked my ignitor chip, CAS, coilpacks, and even swapped new plugs into it but still no fire. My injectors are also not firing off. The only thing i can think of is that my ecu is bad so i ran a check on it and the only code that is showing is 55 (if im counting it right). Any ideas of what it could be that is keeping me from getting any spark?
couped89 is offline   Reply With Quote
Old 10-24-2016, 07:30 AM   #2
couped89
couped89's Avatar
bump. really trying to figure this out before i spend a 100+ dollars on a ecu.
Old 10-24-2016, 08:13 AM   #3
jedi03
check timing
Old 10-24-2016, 08:49 AM   #4
couped89
couped89's Avatar
Just printed out the how to plan on doing that in a few
Old 10-29-2016, 06:29 PM   #5
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
If you're not getting spark or fuel you have a CAS problem or ecu problem. Check to make sure that both CAS pins at the ecu are getting their signal (test at CAS first them ecu)
mr.nismo. is offline   Reply With Quote
Old 10-29-2016, 06:41 PM   #6
couped89
couped89's Avatar
Sorry I forgot to update. I found the issue. I checked everything and found out it was a bad ecu that came with the motor. Ordered a new core with tune from rs enthalpy
