Old 12-18-2016, 05:36 PM   #1
brokenheartedhatch
brokenheartedhatch is an unknown quantity at this point
S13 sr20 problem
So I just bought a black top swapped s13. The car ran great while the previous owner (a friend of mine) was driving it. He mentioned that if it sat for a while without running that it would misfire a little bit. It sat for a month before I picked it up. I drove it onto the trailer and back off the trailer with no problems. And now that I have it in the garage it doesn't want to run. It will start when I hold the throttle halfway open but seems to only be running on 2 cylinders and dies after about 30 seconds. It's got brand new plugs and coil packs. Where should I start my troubleshooting? Maf? Fuel pump and lines?
brokenheartedhatch is offline   Reply With Quote
Old 12-18-2016, 06:18 PM   #2
Gremo
Gremo's Avatar
Gremo can only hope to improve
Do you have consistent fuel pressure?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Gremo is offline   Reply With Quote
Old 12-18-2016, 06:19 PM   #3
brokenheartedhatch
I know that there is pressure at the rail. Not sure if it's consistent. I need to find an extra set of hands.
Old 12-18-2016, 06:23 PM   #4
Gremo
Gremo's Avatar
You can start cheap and swap the fuel filter for a new one. Maybe test the fuel pump relay make sure that's good. Rule out the fuel system then move on to spark. Maybe give your maf a good cleaning too.
Old 12-18-2016, 06:28 PM   #5
brokenheartedhatch
That's kind of what I was thinking.
Old 12-18-2016, 06:32 PM   #6
Gremo
Gremo's Avatar
Check and make sure everything is connected and where it should be. Vacuum lines boost tubes etc.
