Old 10-12-2004, 06:11 PM   #1
ICKY
Account Closed
ICKY is an unknown quantity at this point
Send a message via AIM to ICKY
Rear 5 Lug Swap
Searched here and google and didn't really find anything but questions. I got a pair of S14 SE 5 lub hubs sitting in the garage and I want to put them on my S14 Zenki base model. Anyone know where I can find a write-up on how to install them? I just want to be sure and not screw the car up.
ICKY is offline   Reply With Quote
Old 10-12-2004, 06:35 PM   #2
AKADriver
AKADriver's Avatar
Factory service manual.
If you don't have one of those, grab the S14 SR20DET service manual from the zilvia "tech" page, the installation procedure should be the same. It's just more convenient IMO to have the book than a .pdf
Old 10-12-2004, 06:51 PM   #3
Var
Var's Avatar
Send a message via AIM to Var
http://www.sillbeer.com/5lugswap.php
Old 10-12-2004, 07:12 PM   #4
ICKY
Account Closed
Let me get this streight... do I HAVE to redrill my rotors in order for the hubs to fit? Also, I don't want to take my whole assembly to a machine shop just for them to take the hubs off. Is there any way around this?
Old 10-12-2004, 07:21 PM   #5
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
uve been here since jul 2003 and you ask this?
redrilling the rotor is for people who wish NOT to buy new 5 lug rotors
SilviaDriver is offline   Reply With Quote
Old 10-13-2004, 02:45 PM   #6
Dream240
Dream240's Avatar
damn man they're really cracking down on you. Well, no you don't need to take anything to a shop. Once you get the entire knuckle/hub assembly away from the car, flip it over. There are four bolts holding the hub to the knuckle. remove them and swap hubs, voila, you're done. Then just reassemble the car.
Check here for good pics of the disassembly of the rear end:
http://importnut.net/300zxbrakeswap.htm#rearbrake
Good luck and try to search more to keep from getting flamed. Just a tip.
Old 10-13-2004, 08:12 PM   #7
Touring240
Touring240 is on a distinguished road
Go buy:
5 lug s14 SE rotors
new rear brake pads
2 new cotter pins
remove cotter pins and locking cap
remove 36mm nut
remove 4 bolts holding the hub to the spindle
(turn the rear axle to gain access to each bolt, its a bitch)
pull off rear hub (borrow/rent a hub puller if you want it makes things easier especially if its a rusty car)
If you just have the hub not the hub and bearing assembly you'll have to buy a new bearing or reuse your old bearings and get them pressed on.
Install is the reverse of the removal.
Touring240 is offline   Reply With Quote
Old 10-12-2004, 07:18 PM   #8
Flybert
Just step away from the car. You clearly don't know what the fuck you are talking about and what needs to be done. Go get an FSM and then come back. Seriously.
Old 10-12-2004, 07:36 PM   #9
rainier
rainier's Avatar
rainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud of
Send a message via AIM to rainier
dude seriously on zilvia there are so many 5 lug swap threads. just seriously search harder.
rainier is offline   Reply With Quote
Old 10-13-2004, 12:57 PM   #10
evilimport
evilimport's Avatar
evilimport is an unknown quantity at this point
just buy new 5 lug rotors man, they are freakin cheap and there is a write up in super street this month on the swap...SS sucks but there are pics and instructions there to see everything...
You douche bags bring your A-game?
S14 Zenki face owns all.
evilimport is offline   Reply With Quote
