97% finished s13 built ka24de project !! Must look
What's up, I'm here selling my pride and joy project a lot of blood, sweat, tears were made car is 97 % done you judge it.
Unfortunately , I need to sell because I'm opening up a business and need the money!! No trades or part outs! Location Sacramento BC h-beam rods ARP 2000 bolts CP piston 9:0:1 CP piston rings ARP head studs ARP main studs 248/248 cams Re drilled cam gears Xcessive Intake manifold Custom fuel rail with fittings FID 1000ccd injectors FID pig tails Xcessive upper oil pan REV 9 Sr20 over sized lower Doc racing exhaust manifold Tomei 1.2mm head gasket Celveite rod and main bearings NGK Spark plug wires NGK PLUGS NEW OIL strainer ALL BRAND NEW SENSORS ALL OEM PARTS ALL NEW Gaskets NEW water pump NEW OEM belts NEW water neck NEW oil pump gear NEW front main seal NEW rear main seal NEW Distributor New timing chain kit Mr copper exh gasket P2m thermal intake gasket Cx racing radiator Cx racing E fans Cx racing RaD hoses ISR fuel pressure regulator Mishimoto coolant over flow Mishimoto PS revisor Summit racing An fuel line kit P2m motor mounts Trans : SR trans with KA housing Spec stage 3+ clutch ISR short shifter BLOCK : *Fully balanced rotating assembly with the crank pulley *Polished crank *Block was honed to Piston spec *Surfaced *Align honed *Rings were file fitted ** Piston and Rod combo weighs 1.9 grams from each other** HEAD INFO: Fully rebuilt head *Machined head *3 angle valve job *New seals Motor is a s14 but with s13 accessories ALL PARTS ARE BRAND NEW HAVE PAPERWORK FOR almost EVERYTHING. 89 240sx shell Clean title Reg expired last year Welded diff Non cracked dash S14 seats Full interior Megan track coils Pretty straight Comes with full front end Wheel wells cut ready for tubs Some less shwab wheels with new tires Looking for 5500 obo Only trade I would be interested in is vh45 swap 240 55+ pictures can't upload I don't know why Email me [email protected] |
![]() Join Date: Aug 2005
www.imgur.com to upload photos or should've read the announcements at the top of this thread.
http://zilvia.net/f/announcement.php?f=10
