12-11-2017, 10:21 PM | #1 |
FS: random 1jz/2jz turbo parts. more to be added.
email: [email protected] phone#: 780-940-8561 city: Sherwood Park Province: Alberta Country: Canada below is a 2jzgte hks 2835 twin turbo kit. asking $6500CAD + shipping **WILL NOT SEPERATE** finally got around to getting a complete pictures of EVERYTHING i have for this kit. so as follows: -(2) hks 2835 turbos with 0.61ar silver ceramic coated exhaust housings and polished compressor housings (need rebuilds as they have touched housings as pictured) -(2)hks 2835 turbos with 0.73ar black ceramic coated exhaust housings and original compressor housings.(minimal play) - hks "Y" hotpipe and turbo elbows ceramic coated silver. - hks "Y" hotpipe and elbows polished and modified elbow for hks ssqv positioning. -original turbo oil drain hardpipes for kit with dual return flange to pan -ceramic coated silver downpipes with wastegate recircs -hks 4 bolt wastegates for kit (not sure on the size of these) -ceramic coated black hks exhaust manifold set with junction pipe (gaskets were cut to replace originals, should work) -hks braided steel oil supply hoses and fittings -(2) vibrant 4 bolt turbo outlet flanges in mild steel -(2) vibrant 4 bolt turbo outlet flanges in stainless -(2) hks polished turbo heat shields -(1)hks green mushroom air filter -(2) performance world -10 weld on AN bungs for turbo custom turbo drains -(4) performance world -10AN black fittings to build hoses -(2) vibrant turbo drain -10AN flanges -(4) vibrant black couplers for turbo hot side pipes -(2) genuine hks wastegate outlet gaskets -(2) genuine hks turbo outlet gaskets - new turbo inlet gaskets -new wastegate inlet gaskets -(3) custom made mild steel wastegate outlet flanges(1 has a vband already welded) -(2) vibrant stainless vband assemblies -(1) custom chrome turbo inlet pipe -will include the originally removed gaskets -new hardware on pretty well everything -individual ports on runners for exhaust temp sensors. (all plugs installed at the moment) -kit still needs some work but minimal. I didn't get to complete it as i lost interest. --still need to: build the one intake pipe, 2 water return lines, need 1 air filter assembly, need to make a collector from the 2 downpipes, needs hose clamps or T-bolts for couplers, and will have to build the return hoses if you'd like to do AN line rather than the original steel pipes. -I dont have a 2jzgte anymore so there is no need to keep these around for myself. Asking $6500 CAD for them. Will ship at buyers expense. please pm or text me 780-940-8561 If seriously interested i have more photos that i can send you by email. next is for a 1jzgte: -hks3037 single turbo kit. ball bearing. could use rebuild as there is play. manifold. 50mm hks 4bolt wastegate. -oldschool hks fcon with patched in 1jz harness. -clutchmasters twin plate clutch. used. -1jz/2jz front sump oil pan setup. as well as a rear sump setup. both used and dirty. -$2000CAD FIRM for the above **WILL NOT SEPERATE**. will ship at buyers expense. pictures will be taken of these 1jz parts soon. -1jz to bmw e36 engine mounts (dont know brand) $150 Last edited by 2jz300; 12-12-2017 at 09:35 PM.. |
1jz, 2jz, nissan, toyota, turbo |
