S14 zenki 400hp built sr + top mount
Hello, im looking to part ways with my 1995 zenki s14. ive owned the car for a little over 3 years. the car has the following:
Chasis: 1995 clean title 117k curb weight: 2750 full interior and tank of E85 Drivetrain: s14 black top carbon haet diversion panel full blueprint port and polish HKS 264 cams BC titanium valve springs and retainers HKS Rocker arm stoppers ARP Headstuds tomei 1.8mm headgasket Manley rods CP pistons Greddy Trust baffled oil pan SR20DE lifters Radium Top feed Fuel rail ID 850CC injectors Radium IACV spacer ISR FPR Innovate dual function gauges AEM wideband full gplus hoses ISR radiator hoses Walbro 450 pump hallman pro boost controller/with ball bearing upgrade Koyo Radiator dual fans/with metal shroud tf works valve cover hardware Apexi Power FC Standalone ECU Signal Wiring Harness full stainless steel braided lines for catch can E85 ONLY Top Mount GT3582 with .63ar and quick spool housing from Twisted Motion Top mount ironman Manifold by Twisted Motion Tial 44mm External Waste gate 11psi spring Z32 MAF Custom Cx racing intercooler piping done by RAD Industries Custom stainless wastegate screamer pipe (v band) by RAD Industries Custom downpipe (v band) by RAD Industries KAAZ 2-WAY Differential in j30 pumpkin Tomei Titanium 10lb exhaust Custom heat shield for upgraded brake master S14 5 speed transmission Competition clutch stage 4 kit ACT 11lb Fly wheel ISR short throw shifter Suspension: ISR Pro Arms front and rear Rival Auto Works angle kit Energy steering rack bushings Stance XR1 Coilovers Nismo front and rear strut braces OCMA alignment Brakes: Z32 Calipers upfront drilled and slotted rotors Earls Stainless Steel braided lines Exterior/Aero: Rocket bunny Real Rear bumper( custom Led license plate light BN Side skirts OE front Bumper with holes for the intercooler(and cool guy points) wingless trunk Authentic Silvia grille nismo vented hood 3M 240 1080 white and gold flake wrap Dmax D1 Spec +30mm front fenders PSWRD JDM quick releases Interior: full interior pioneer speakers retro hideaway style kenwood headunit 10inch sub aftermarket avatar alarm system aftermarket Amp Nismo Butt plug shift nob Bride low max (driverside) Corbeau fx-1 Pro (passenger) Buddyclub rails (driverside cut and lowered, was too tall with stock Buddyclub rail) non-cracked dash Car puts down 400hp at the moment on a conservation tune at 13.5 PSI Tuned by Koji at Autotalent engine has approx 2400 miles on it tracked two events and the rest is street driven not really looking for trades unless its an R32 Sedan or 370z or something full AC Price:13k pics found at: https://inlandempire.craigslist.org/cto/6712474827.html |
