FS/FT 1992 SR20VET VVL S13 Silvia
SOLD!!!!!
1992 Nissan 240sx Coupe (Rebuilt Kansas Title) 161k miles SR20VET built engine: S13 block - stock crankshaft, stock sleeves 86.5mm 9.0 compression CP pistons Eagle rodsstock sleeves ARP head studs ARP main studs Apexi head gasket P11 VVL head P12 valve cover GT35 Garrett turbo CBR ignition coils AEM Series 2 EMS AEM Twin-Fire CDI box Kelford camshafts Brian Crower dual valve springs Z32 Transmission Nismo 4.36 final drive 2 way LSD. Mazworx VVL conversion kit Mazworx Turbo kit Mazworx Z32 transmission kit Tuned on E85 at 24 psi making 495whp. It actually probably makes around 600hp but this particular always dyno reads low. It’s just as fast as my buddy’s RB26 S14 with 800+ hp. Body: Fresh paint S13 Silvia aero front end conversion Triple projector headlights with Acura TSX projectors retrofitted and 6000K HID kit Nismo LMGT2 wheels Bride Seats US HUD cluster with 9000rpm JDM tach swap Chassis/Suspension: Full Z32 brake conversion Lowered on coilovers Coilovers need replaced - blown Chase Bays harness Current problems: Oil leaks (nothing major) RF brake caliper leaks Blown coilovers Speedometer and fuel gauge inoperative, A/C inoperative - haven’t worked since the chase bays harness install and I just haven’t messed with it enough to figure it out. P/S whines Cruise control cable needs bracket welded to intake to work Fuel door cable needs replaced - have cable. Looking to sell for $10,000 cash or trade for something of equal value. Would prefer trades that are pretty close to stock or no major mods. I’m tired of working on stuff. Can text or call me at 6203915771. I’m sure I’ve forgotten some things. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 240sxConvert; 12-30-2018 at 01:16 PM.. |
Nothing crazy special. The JDM HUD cluster used a 9000 rpm tachometer. Basically you can buy a JDM HUD S13 cluster (Make sure you get the correct one for your setup because the SR & CA use different tach signals) and swap the cluster in the car, but it will only read in kmh and so I swapped just the tach over to my USDM cluster. You can also use a tach out of a non-HUD cluster but it has to trimmed and looks cheesy. Thanks
The rebuilt title is due to right front accident damage that occurred a few years ago. It takes very little for an insurance company to deem an old car a total loss...
#7 | |
![]() Join Date: Feb 2012
The repair job looks to be quality. Nice panel alignment on the fenders, doors, and hood. Do you have a dyno sheet? I'd love to see if the VET helps with lag. I make a similar power on my SR (540 rwhp) and don't hit full boost until ~4500.
Road Racing FTW Last edited by NY2NV Miner; 11-18-2018 at 07:55 PM.. |
