Old 11-10-2004, 05:46 PM   #1
XXX4life
XXX4life is an unknown quantity at this point
Send a message via AIM to XXX4life
where is all my gas going?
i have a 90 240 with a 91 ka24de that i just put in a few weeks ago, i put in 7.5 gallons of gas the other day and i've driven 65 miles and it's almost on empty? why am i only getting like 10mpg? it's got new plugs, cap, roto, wires, new fuel filter, new airfilter, what could it be?
thanks
04 Scion xb
90 240sx (ka24de)
www.entrustclothing.com
XXX4life is offline   Reply With Quote
Old 11-10-2004, 06:17 PM   #2
Shin_Kudo
Shin_Kudo is an unknown quantity at this point
Never mind
'95 240SX Base Pearl White
Shin_Kudo is offline   Reply With Quote
Old 11-10-2004, 06:19 PM   #3
Flybert
Leaky injectors, bad O2, fuel line leak, etc. Check your plugs and see what they look like.
Old 11-10-2004, 08:32 PM   #4
mistaanime
mistaanime's Avatar
mistaanime is making a name for him/her selfmistaanime is making a name for him/her self
Send a message via AIM to mistaanime
put the KA24E engine back in there..lol...nah..i dunno..my guess would be bad o2..like flybert said..
-Cherry Red 91 Silfourty-
mistaanime is offline   Reply With Quote
Old 11-10-2004, 09:43 PM   #5
XXX4life
it was bad with the ka24e in too
04 Scion xb
90 240sx (ka24de)
Old 11-11-2004, 04:01 PM   #6
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
fuel leak. der.
andrave is offline   Reply With Quote
Old 11-11-2004, 05:18 PM   #7
XXX4life
it's not a fuel leak, i would know if my fuel was leaking
04 Scion xb
90 240sx (ka24de)
Old 11-11-2004, 08:02 PM   #8
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
thanks
Bad float sensor?
400x200
mbmbmb23 is offline   Reply With Quote
Old 11-11-2004, 08:26 PM   #9
weirdstyles.net
This guy...
weirdstyles.net's Avatar
weirdstyles.net is an unknown quantity at this point
Send a message via AIM to weirdstyles.net
stop beating it?
My project car...
From dust you were born,
And to the ashes you return ~ Kill Switch Engage
Family Guy
Quagmire: Hey, how old are you sweet thang?
Connie: 16.
Quagmire: 18? Alllll-right!
Connie: Mommmm!
Quagmire: I like where this is going, Giggidy giggidy gig-gi-dy!
weirdstyles.net is offline   Reply With Quote
Old 11-11-2004, 08:34 PM   #10
idlafie
idlafie's Avatar
You might want to check these threads....
http://www.zilvia.net/f/showthread.php?t=63587
http://www.zilvia.net/f/showthread.php?t=54065
If your going thru gasoline like there is no tomorrow then you might want to check your ECU first before you attempt any repairs. Put your ECU into Diagnostic Mode...see www.240sx.org FAQ page for instructions. Once you put your ECU into Diagnostic Mode, then check to see what type of Diagnostic Trouble Codes your car is kicking out.
Once you pull the Diagnostic Trouble Codes, then pop the hood of your car & try to figure out what may be causing your problem. Areas to check are.
1). Fuel Regulator....sufficient / not enough / too much vacuum going to the Fuel Regulator??
2). Fuel Injectors...is one or more leaking??
3). Engine Cooltant Temperature Sensor - a faulty ECTS or bad wire leading to your ECTS may have your ECU thinking your engine is still cold & causing the extra fuel to be dumped in your intake manifold.
4). Idle & Timing...check your Idle & Timing - make sure they are set properly
5). Oxygen sensor - test it thru the ECU..The Check Engine Light .should flash 5 times or more in a 10 second period when the ECU/O2 Sensors are placed into Diagnostic mode.
Check these items out & let us know what your results are..
Anyhow, hope this helps..
ID
Old 11-12-2004, 05:29 AM   #11
Blues13
Blues13 is an unknown quantity at this point
If the car is running fine and no signs of irregular conditions, then prob a fuel leak as suggested before. Did you check the ALL of the lines?? Sometimes its not so obvious, mine was a slow leak by the fuel tank under the car.. and ended up getting bout 14mpg.
Blues13 is offline   Reply With Quote
Old 11-12-2004, 08:20 AM   #12
XXX4life
we replaced all the fuel lines in the engine bay when we did the swap, but i will check the bad of the car, the full thing is i swapped a DOHC into my car b/c my SOHC was getting such bad milage and now i'm getting worse with the DOHC
04 Scion xb
90 240sx (ka24de)
Old 11-12-2004, 08:24 AM   #13
andrave
andrave's Avatar
yeah my infiniti was leaking at the injectors and it was getting horrible gas mileage and I didn't even realize it. glad I caught it and had the recall done before my car burned down.
Old 11-12-2004, 09:24 AM   #14
XXX4life
is there a way to tell if my injectors are leaking?
04 Scion xb
90 240sx (ka24de)
Old 11-12-2004, 12:38 PM   #15
89s132b
89s132b is an unknown quantity at this point
Yes, unbolt the fuel rail and lift it out of the manifold. Keep all the fuel lines and injectors intact. Turn your key to the "on" position so that the fuel pump will prime. If you have leaky injectors, you will see fuel dribble out of the rail. If they DO leak, just change out the lower o-rings. I can send you some or you can buy some from your local nissan dealer for about $1 each. If they are leaky, I'd suggest replacing all the o-rings.
89s132b is offline   Reply With Quote
