Old 11-15-2004, 01:00 AM   #1
silguy
silguy's Avatar
silguy is a well-known jackass
Clutch slipping, what should I check for??
Sup, my clutch slips or have the similar symptom when the engine gets really warmed up(after 15 min). What should I check for? I just replaced the transmission and clutch(oem exedy replacement). The clutch was broken in correctly. it was fine for about 2 months until recently. AFter it gets really warmed up, u can floor it in any gear and it will start to rev then slowing catch.....thanx in advance...
silguy is offline   Reply With Quote
Old 11-15-2004, 10:36 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Did you re-surfaced the flywheel and made sure that you clean/degreased it when you installed the clutch? You could have glazed the flywheel already if you didnt.
Old 11-17-2004, 01:51 AM   #3
silguy
silguy's Avatar
yes, i resurfaced the flywheel....etc. It was working fine for 3 months and now its doing this.....I pushed the car hard and drifted in that period AFTER the clutch break in... The weird thing is...it doesn't do it when its cold, only when it gets really warmed up.
Old 11-17-2004, 02:02 AM   #4
Dweezil
Dweezil is an unknown quantity at this point
sounds like the pressure plate spring has overheated at some point.
Originally Posted by tah
I would buy myself breast implants so I could play with some titties without getting slapped.
Dweezil is offline   Reply With Quote
Old 11-17-2004, 02:09 AM   #5
silguy
silguy's Avatar
wut da hell...that sux to hear. Damn..that means i have to drop the tranny again...ain't that a bitch. Any other opinions...possibly throwout bearing.?? thanx
