Old 03-29-2020, 01:39 PM   #1
spools420a
spools420a's Avatar
spools420a is a well-known jackass
interchangable injectors from junkyard?
Hey all I was wanting to know what injectors can be used interchangable in sr20det that come from other make/model cars ie,. sti ford etc.
I have to run to the yard and might pick some up to clean and flip becauase i have a new ultrasonic i wanted to test.
was it the mustang that had side feeds we can use?whats the cc as well and thanks.
spools420a is offline   Reply With Quote
Old 03-29-2020, 03:47 PM   #2
foreverdeath
foreverdeath's Avatar
foreverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the roughforeverdeath is a jewel in the rough
Sure lots can fit but sidefeeds that flow more then the stock sr20det 370s Is kinda limited to Turbo Subaru and S15. You snatch VH45DE injectors as they are 370cc. Switching to top feed adds alot of options like 640cc or biggrt IIRC off of 13Bs (each engine only has a pair tho). Supercharged v8 and E85/FLEX compatible vehicles are good candidates for big stock injectors.
If you search enough you will find a collaborated injector list on another forum, I dont think I have it bookedmarked anymore. I dont think it was new enough to list flex fuel cars thi.
Sent from my SM-G960U using Tapatalk
foreverdeath is offline   Reply With Quote
Old 03-30-2020, 08:16 AM   #3
jedi03
i got some used 550s from subaru with pigtails!
Old 03-30-2020, 09:20 AM   #4
TheRealSy90
TheRealSy90's Avatar
I don't know of any american engine that uses 370cc sidefeed injectors.
Such a good signature.
Old 04-06-2020, 08:18 PM   #5
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
lol I am dead
If you are going to use E85 just convert to a top feed set up. IMO there are no side feed injectors on the market that can efficiently use E85.
If you need some really good side feeds though I highly recommend Nismo 740cc Super reliable & quality. I did not want to fuss with any bs so I spent the money and zero issues. Got my car on the dyno & started making power
s13 @ fullboost is offline   Reply With Quote
