09-11-2020, 07:36 PM | #1 |
s14 a/c condenser in s13?
Does anybody know if an s14 ac condenser will fit into an s13 without any modification? I converted my ac system to r134a and feel like the performance sucks with the stock condenser and want to switch to the parallel flow s14 condenser. Any info on this would be appreciated.
09-12-2020, 02:39 PM | #3 |
Yeah from what i seen as well i would need the s14 lines. But other than that I dont see why it wouldnt work. The measurements are both 13x24 for s13 and s14 condensers. All of my pressures are fine nothing abnormal and the reason i wanna switch is because the older style stock s13 condensers dont cool r134 very well. Im also having issues with the air getting warm when the car comes to a stop. The parallel flow s14 one was made for 134a which is why i want to switch.
09-12-2020, 09:11 PM | #5 |
Stock fan clutch, stock electric condenser fan. I previously had on dual electric altima fans which made the actual temperature of the car extremely cool but the ac performance was the same. Still would get warmer in stop and go. I should mention also when I charged the system I charged it with the exact amount of refrigerant using a scale so it cant be low.
09-13-2020, 12:03 PM | #6 | |
edit forgot the useful part. you will get further cooling by doing a good recharge ie. change out the dryer, pull a vacuum for as long as you can (6+hrs) to remove all water etc. flush the lines, and ensure you have proper r134 pressures (you should be using a r134 sensor with the conversion? |
09-13-2020, 05:20 PM | #7 | |
09-13-2020, 05:43 PM | #8 | |
09-13-2020, 07:13 PM | #10 |
It all depends on a day where its 105 out the pressures are usually around 40-50 low side and 250-300 high side. When its 90 degrees out pressures are usually about 25-35 low side and high side is 150-225.
09-14-2020, 06:33 AM | #12 |
That's why i'm at where i'm at. Everything checks out, everything functions as it should which is why i'm thinking the condenser just isn't efficient with r134a. It is a know issue with serpentine style condensers which is what the stock s13 condenser is. They work great with r12 but not 134a. There is no issues with compressor cut-outs or anything. The problem is only when idling or stopping.
09-14-2020, 08:18 AM | #13 | |
I'm interested to see your lines/fittings. |
09-14-2020, 08:34 AM | #14 | |
09-14-2020, 09:31 AM | #15 |
are you using a full shroud with the stock fan? if its only at idle your not removing the latent heat from the ac system which is impacting your ac performance. can you feel air being drawn across the condenser? do you have a FMIC on the car? improving your air flow across the condenser will fix this issue (provided everything else is fine from the conversion) of poor cooling at idle (assuming this issue is only at idle) |
09-14-2020, 09:37 AM | #16 | |
09-14-2020, 09:53 AM | #18 |
I was just looking into that, they use different condensers at least different part numbers from what I have found after 95. They also seem to have r134a fittings in the pictures I have seen. 95 is the year r134a came out so I think those might be parallel flow condensers or they could be the same style I have no idea honestly. They have kind of a weird design and everything also goes back to one side back to the evaporator box but I'm sure it would work with some fabricated lines. If the s14 condenser doesn't work this would probably be the next best bet. Don't know how hard they are to find, it seems like there are more s14 condensers around.
09-14-2020, 10:31 AM | #19 |
Have you considered HPI's s14 Radiator Rescue condenser?
I don't think they ever made them them for s13s but from what I remember when I went down this rabbit hole is that they designed the condenser to cool as well as oem while blocking less air to the radiator. No idea how a rhd s14 condenser would work with lhd s13 AC lines. I'd assume you could flip it around/upsidedown and maybe get some small conversion lines so the factory lhd s13 lines hook up and if you're already modifying an s14 condenser into an s13 that really doesn't seem like too much more work. And the condenser is probably actually going to be designed for r134a and it'll probably be alot easier to just buy a new one than having to find and probably ship a used kouki 180sx from japan and still deal with the rhd issues. I found the measurements for the hi pressure/low pressure houses on rhd japan so you could measure yours and at least know if the fittings will physically fit https://www.rhdjapan.com/hpi-radiato...5-4mm-s14.html https://www.rhdjapan.com/hpi-radiato...0-1mm-s14.html |
09-14-2020, 10:48 AM | #20 | |
(s13) https://www.nissanpartsdeal.com/reso...2e39ff502c.png (s14) https://www.nissanpartsdeal.com/reso...ed70e50015.png (180sx) https://image.nengun.com/catalogs/im...terisk_003.png (s14 silvia rhd) this is probably how the routing would be with the hpi condenser https://image.nengun.com/catalogs/im...terisk_001.png |
03-28-2023, 01:04 AM | #21 | |
05-04-2022, 12:44 PM | #23 |
US-spec S13s went to R134a in mid-1993. So the parts are rare but they exist. Mostly 1994-titled convertibles, but my 1993 hatch has factory R134a. In the factory parts diagrams they give the break as 5/1993. kennn and I found a complete S13 R134a setup in a junked car about 10 years ago. Look for the blue stickers on all the hoses and one on the firewall by the clutch master.
Condenser is part number 92110-53F10 (vs. -53F01 for R12). Aftermarket suppliers only list one replacement for both, so... the differences may only be stuff like the "R134a only" stickers on every part of my system and the fittings and o-rings. S14 condensers are a different shape but the same general size, I've never had mine out of the car so I can't say as to how well a different one would fit. Just checked on Rockauto and interestingly the only S13 KA24DE A/C compressor they sell now is for the '94. Suppliers photos look bang on identical to an S14 compressor so I couldn't tell you the differences. My factory compressor has the fittings in the same config as those two. |
05-04-2022, 03:10 PM | #24 | |
Really wish they still sold the S13 condensers new. Does anyone know of any R134a Nissan/Infiniti condensers the S13 could maybe interchange with?
Instagram: Nismo_Lk Last edited by JrDarknes; 05-04-2022 at 04:15 PM.. |
05-04-2022, 07:28 PM | #25 |
TK3 bros!
I would start by looking at S14 condensers, since you know the radiators are the same dimensions, and even though the lines bend differently you could likely use most of the S14 lines. The lines meet the evaporator differently though. B14 condensers look like they might be a bit smaller. Could maybe work. J30 and Q45 stuff look big enough for a house. |
05-05-2022, 08:59 AM | #27 |
have you cleaned the fins on the radiator/condensor? if they are good along with pressure then i would look at the pump, based on your symptoms...just had a 09 expedition which had no leaks, no issues anywhere else, I checked flow for the rest of the system in case the restrictor had failed, the compressor was no longer pushing anything through it...I have never had a compressor apart but it either uses rubber o-rings or other style to make compression as its a simple 2 piston pump inside
04-07-2023, 02:32 PM | #28 |
the condenser doesn't fit natively, but it can be installed with with some effort. I recently did a LHD s14 AC into a LHD s13 with sr20. Here's my write up https://zilvia.net/f/showthread.php?t=681093
Tags |
240sx, a/c, s13, s14 |
