Old 11-02-2020, 05:16 PM   #1
Quiche2192
Quiche2192 is an unknown quantity at this point
SR20DET Redtop Coolant Pipes
I'm rebuilding my SR and I've found the coolant pipes to be in really bad shape. I can't find any online. Anyone know what I can do to either fix or replace them? Anyone know where I can find replacements? I've already spoken to someone to replate them, but there's a risk of the sandblaster blowing through the badly corroded parts. Here's an example of what I'm looking for: https://www.efisolutions.com.au/heat...x-discontinued
Quiche2192 is offline   Reply With Quote
Old 11-02-2020, 06:42 PM   #2
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
If it's no longer available new, best bet is the WTB section.
Try and have them sandblasted and see if the corrosion is really that bad.
lok is offline   Reply With Quote
Old 11-02-2020, 06:55 PM   #3
S14rebuild
Wouldnt be that hard to tig a set of pipes up to recreate them.
Old 11-10-2020, 06:32 PM   #4
Quiche2192
Those of you that have bypassed the throttle body and IACV coolant lines, any issues with starting the engine in cold conditions? I'm in the Southeast so I'm not too worried, but I'm still curious. I'm thinking about just getting rid of all the piping and just running the coolant line to the turbo using the mazworx VE water neck
Old 11-10-2020, 06:49 PM   #5
S14rebuild
I have deleted tb n ivac lines, not 1 issuse
Live in south florida n daily drive the car like that for years
Old 11-10-2020, 06:35 PM   #6
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
the coolant to the TB is for helping engine warmup, not startup. I've never had it hooked up in all sorts of climates. It's fine.
zombiewolf513 is offline   Reply With Quote
Old 11-10-2020, 06:55 PM   #7
zombiewolf513
you deleted the lines to the iacv? it needs those to function properly at different coolant temps
Old 11-10-2020, 07:08 PM   #8
S14rebuild
Yup...never once had any issuses. Idled solid at 900rpm. Every time cold start, hot start 70 degree out. 99degree out. Worked perfect.
I was hesitant todo it. But came across a few threads here and i went for it. Worked good for me
Old 11-10-2020, 07:10 PM   #9
zombiewolf513
good to know
Old 11-11-2020, 08:59 AM   #10
S14rebuild
Helped be declutter the mess of hoses under the intake.
Only have 1 hose there now, running from the side of the head to the back of the thermostat housing. Been convered to -10an line. Should have no leaks or busted hoses again. Looks super clean too
Old 05-29-2021, 09:02 PM   #11
240boosted
240boosted has a little shameless behavior in the past
Not thread jack but I like one also wish could find one without buying a motor
240boosted is offline   Reply With Quote
