Old 04-25-2021, 03:02 PM   #1
K_never_broke_again
K_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura aboutK_never_broke_again has a spectacular aura about
[SOLVED]transmission difficult to shift
ok I did search through here and found some good info but nothing gave me a good answer. So basically my transmission is very hard to shift, through all the gears, to the point where i have to put all of my weight on the shifter. reverse is especially bad, itll grind every time you have to pretty much jam it in there if you want to use it. This problem started a couple months ago, it wasnt all of a sudden but more of a progressive thing. so far ive adjusted the pedal, replaced the clutch fluid, bled it, replaced the slave, none of that did anything. today I dropped the trans, hoping to find a messed up fork or throwout bearing, nothing at all. everything seems fine with the the fork and the clutch as well(all springs are intact). so at this point what could the problem be? I replaced the master cylinder about a year ago I find it hard to believe thats the problem. The slave cylinder is extending all the way as well. I also cant see it being the synchros as theres difficulty in every gear especially reverse which doesnt even have synchros. at this point im stumped, probably going to do the shifter bushings and the master cylinder for the hell of it, but besides that does anyone have any ideas of what the problem could be? I was thinking maybe the soft line portion of the clutch line is expanding causing the clutch to not disengage all the way. if anyone has any ideas please let me know!!!
K_never_broke_again is offline   Reply With Quote
Old 04-25-2021, 04:28 PM   #2
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
Hmm interesting
I?m going to keep an eye on this thread
It?s not on my 240 but it?s something I feel on my Infiniti G20
I changed the tranny fluid and made sure I used GL4 fluid which nobody had in stock and had to order it online
Did notice a little bit of difference more of an improvement
Did you use the right fluid??
andisan is offline   Reply With Quote
Old 04-25-2021, 04:52 PM   #3
K_never_broke_again
used redline mt90, however i did notice the level was a little low probably due to the leak in the rear seal. You think that could be part of the problem? it wasnt super low probably half an inch under the fill plug. Now that I think about it that would explain the slow onset on symptoms. still dont know how that would explain it being so rough into reverse tho. When i put it back in this weekend im doing all new fluid maybe thatll make a difference.
Old 04-27-2021, 08:03 AM   #4
jedi03
i have found that royal purple 75w-90 works great...maybe its the weight of the oil you are using? when you had the trans dropped were all the spring fingers an equal height? is there oil on your clutch/flywheel? if you have someone push the clutch in make sure the disk actually releases and doesn't stick otherwise
Old 04-27-2021, 10:58 AM   #5
K_never_broke_again
spring fingers look good, from what i could tell the clutch was bone dry. Oil being on the flywheel behind the cutch i feel like could be possible, when i put it back in Im going to have someone watch through the fork hole while i push the clutch in
Old 04-27-2021, 08:39 AM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
does the trans shift smoothly with the engine turned off?
Old 04-27-2021, 11:01 AM   #7
K_never_broke_again
when you first turn it off, it doesnt. however after Ive gone through all the gears a few times is starts to be smooth again. im not really sure what that means but i feel like it might be a significant piece of the puzzle
Old 04-27-2021, 01:48 PM   #8
burnsauto
burnsauto's Avatar
Did you ever check how the transmission shifts when you had it out of the car and were inspecting the fork and such? Sounds like you may have to remove the front and rear housings from the transmission and see what's going on there. Sounds daunting, but it's not too hard to do.
Old 04-28-2021, 07:09 AM   #9
K_never_broke_again
i did actually, and it seemed to shift fine. Im gonna twist the input shaft tho and try it again and see what happens. if its shifting rough again imma crack the case open and update with my findings. THANK YOU FOR THE RESPONSES EVERYONE!!!
Old 04-28-2021, 02:53 PM   #10
Tieny
Tieny is an unknown quantity at this point
If its hard shifting through ALL the gears, it makes me think its a disengaging issue. Have someone press the clutch in while you look to see how much the clutch fork is moving. If the fork isn't pivoting much it'll not release your clutch fully causing the hard shifting.
Also see if you can shift through the gears when the engine is off. (Which I see someone has asked)
Basically if you are able to shift through the gears while the engine is off, then it definitely leads to an disengaging clutch issue. But you said "once you first turn it off, it doesn't" until after you shift it a few times (I'm assuming because it's still spinning a bit before fully stopping).
Just to make sure you can shift through easily with the engine off, have the car lifted from the rear and spin the rear tires a bit and then try shifting through the gears again. Repeat a this a couple times. If you're constantly getting hard shifts at first and then smooth, I would think your gear teeth/hub teeth are pretty bad and rounded throughout the tranny. (bad/worn dog keys within the trans can also cause this since it won't provide a decent range for the syncho hub teeth to align with the gear teeth. - requires rebuild)
fyi: reverse gear will always be the worst worn out gear out of all of them so that's normal even in decent working transmissions.
after reading through the thread, I would most likely think its a disengaging issue first.
Tieny is offline   Reply With Quote
Old 05-29-2021, 06:53 PM   #11
K_never_broke_again
UPDATE: due to some delays caused by the end of the school year it took me a little longer to get everything back in than I thought it would, but I finally got it all buttoned up. Unfortunately theres still no change. I have verified everything is working mechanically in the disengagement portion of the clutch, and I replaced the slave/master cylinders with oem units straight from the stealership. I also replaced the rubber softline going from the hardline to the slave with an aftermarket braided line to ensure no type of expansion/loss of travel is happening. At this point the only explanation is that theres something wrong with the internals of the trans like some of you have been suggesting. I was really hoping it wouldn't come to this but I dont see any other option besides dropping the trans again and cracking it open. if the dog keys/gears Tieny mentioned are alright and all I need is a synchro rebuild, I plan to do it all myself. Seeing as these transmissions are so rare these days I'll probably do some kind of writeup on it since buying a new one isn't so easy or inexpensive. All of this right as I get my kouki front end :'(((( thank you again for all the help I'll probably update this thread again once I crack the trans.
Old 05-29-2021, 10:16 PM   #12
andisan
andisan's Avatar
Ok sorry to hear and yeah waiting to see a write up from you
Thanks for the update
Old 06-03-2021, 12:38 PM   #13
zer0c123
zer0c123 is an unknown quantity at this point
When you dropped the tranny, did you check the pilot bushing?
Sent from my Pixel 4a using Tapatalk
zer0c123 is offline   Reply With Quote
Old 06-05-2021, 08:05 PM   #14
K_never_broke_again
I didn't, however I installed a new one about a year ago so I figured theres no way i could be bad. Ill take a look at the pilot bearing tomorrow along with the clutch again
Old 06-05-2021, 08:23 PM   #15
K_never_broke_again
update: pulled the trans trans today and cracked the case. I have to say I'm very disappointed, I was hoping to see something catastrophically wrong with it but unfortunately I didn't see anything I thought was too crazy. I'll admit though I have no idea what im looking at so i took a few pics, gonna include them here maybe you guys have some ideas.
https://drive.google.com/file/d/1-8g...ew?usp=sharing
First gear^ besides reverse this gear has given me the most trouble by far. you can't see the synchro in the pic but the teeth on it look alright, similar to the other gears.
https://drive.google.com/file/d/1YNi...ew?usp=sharing
second gear^. out of all the synchros this one looked the most ragged.
https://drive.google.com/file/d/1gG2...ew?usp=sharing
reverse^ apparently reverse does have a synchro. You can see the teeth on the gear here are pretty messed up. explains why it always grinds in.
Thats all I got for pics atm, if anyone wants me to post more im happy to share. gonna check out my clutch again tomorrow
Old 06-06-2021, 11:10 AM   #16
burnsauto
burnsauto's Avatar
besides the synchro's, check for bearing play, check the fluid that you drained for any kind of particulate or material (check with a flashlight, put it through a paint strainer)
How long have you owned this transmission/how many miles have you put on it? It's a bit odd that the teeth on the hub for reverse are worn so badly, but the synchro for it looks like it hasn't taken any abuse...I'd think it would be the other way around, but maybe I'm wrong about that.
Old 06-07-2021, 10:54 AM   #17
K_never_broke_again
trans came with my sr motor, I really don't think it has many miles at all I'd guess around 100k. I also found the reverse gear/synchro strange, as I watched a video which says gear wear like that points to a disengagement issue.
this brings me to my next point... I think I found I may have found the real problem. the other night as I was staring at my trans, I started absentmindedly scraping stuff off my input shaft. And I dont mean grease, but actual metal burrs that had accumulated between the splines(possibly from wear/clutch kicks?). I had to actually scape them off with a pick. somehow the back inch or so of it was all jammed up with it. My guess is that theres actually nothing wrong with the transmission at all... I think the shit on the input shaft wasn't allowing my clutch to fully disengage, as the clutch needs to slide along it. This also matches up with all my symptoms(happened slowly over time, affects all gears, feels like disengagement problem). At this point i'm crossing my fingers and putting everything back together. hopefully it'll be done by tomorrow night and I'll have an update.
Old 06-07-2021, 02:14 PM   #18
burnsauto
burnsauto's Avatar
that could be your smoking gun. Just try and track down where those metal shavings are coming from.
Old 06-14-2021, 09:52 AM   #19
Tieny
how did the reassembly go? Just saw the update and didn't get a chance to give a reply til now. Yep, the worn reverse gear teeth is pretty common. That's what happens when people don't completely stop before switching to reverse. The synchro prevents the grind but a lot of stress is still put on it. Like after getting out of 1st gear and you try to putting it back, (especially at higher speeds), you can do it if you keep pushing the gear in but the synchro works hard as shit to get it to slow in.
The teeth on your lower gear synchros do look pretty worn though. They should be straight on the sides and then taper up to a point. Check out the 5th gear syncho, that gear is usually less worn out if you want to compare.
If you have burrs on your input shaft, it could cause the clutch to seize on that burr while trying to disengage which would cause your issues. Do you have any photos?
Old 06-14-2021, 01:05 PM   #20
Kingtal0n
Kingtal0n's Avatar
I rebuilt 3 different SR transmissions. They make some with reverse synchro and some without.
The input shaft, throwout bearing, fork, all need a healthy coating of molybdenum disulfide grease. The FSM specifically says this so check it out.
Yes debris accumulated on the splines directly contributes to the clutch disengagement and this could well be the major issue. Honestly there isn't much that I've seen that can actually go wrong with these transmissions beyond an obviously broken shaft or gear. Seems like they last forever if you just clean them up and use the right grease.
Old 06-15-2021, 10:04 PM   #21
K_never_broke_again
update- SOLVED!!!! alright so the rusty splines were not the problem. I lubed them up and nothing happened, so i said eff it and I bought a new clutch. so I just pulled it off, and sure enough one rivet of the friction plate part of the clutch popped off the spring. I haven't actually verified my trans shifts better but I see no reason why installing this new clutch wouldn't fix it(if it doesn't fix it my mind will be BLOWN). lesson learned here is be thorough with inspection, because this whole headache could have been avoided if I actually took my time instead if rushing through things. leaving a pic of the clutch as well.THANK YOU ALL FOR THE RESPONSES!!!!!
https://drive.google.com/file/d/1nwP...ew?usp=sharing
broken clutch^
Old 06-16-2021, 06:48 AM   #22
burnsauto
burnsauto's Avatar
Well, you found a symptom of the cause (why I recommended you keep looking to find where all that buildup of material was coming from) Unless you're doing heavy driving that burns up clutches quickly, you shouldn't have that much material (either clutch disc or metal shavings) build up like that. That missing Rivet (and I'm just spit-balling here) was probably causing uneven wear on both the pressure plate and the clutch disc, and causing that build up on the input shaft. Glad you figured it out (fingers crossed).
Old 06-16-2021, 06:42 PM   #23
Tieny
Nice! It’s good to see posts being actually being solved. That missing rivet on the pressure plate would definitely cause an uneven disengagement where it’s probably only pressing on half the clutch and not fully disconnecting the clutch from the pressure plate. As for causes on why that might break? Only thing I can think of is too much clutch kicking and launches. The plate looks okay besides the uneven contact areas, (you can see the marks where it only contacted in the area near where there are still rivets), but with no obvious burn marks so I didn’t think excessive heat was it. Or it could be cheap parts
Old 06-19-2021, 12:20 PM   #24
K_never_broke_again
Originally Posted by Tieny View Post
Nice! It?s good to see posts being actually being solved. ... Or it could be cheap parts
I've read through so many promising threads just to find they were never solved, its very frustrating lmao. And that clutch was def cheap, I got it as part of a swap package from enjuku. the rivets on my new ebay clutch look much beefier. anyways, put everything back together and it shifts like BUTTER.
One thing I'd like to mention before this thread goes into the archives... something I should have mentioned was that my trans was grinding into reverse EVERY TIME, even with the car stationary but with the engine on. Thinking about it now that showed definitively that it was a disengagement problem, which I think many of you told me lmao. what made it so confusing though was that my rear wheels were not moving when I had the clutch pushed in(in first). turns out while it was sitting the e brake seized up so I couldn't tell the wheels were supposed to be moving
Thats everything, problem solved and onto the next. thanks again guys zilvia gotta be the realest forum ever.
Roll Credits:
andisan
jedi03
brndck
burnsauto
Tieny
zer0c123
Kingtal0n
Old 06-16-2021, 07:23 PM   #25
Kingtal0n
Kingtal0n's Avatar
I would never use a typical clutch on an sr20 anymore. Only Ogura single or twin plate from now on IMO.
Old 06-28-2021, 07:51 AM   #26
jedi03
rofl +1 glad to see resolution! have not seen the spline issue before! but new stuff always happens lol! now go enjoy that transmission!
240sx, transmission
