s13 front spacer question
Hi, I was looking into suggestions for what size front spacer to use on my 4 lug front hubs. I will be putting on 17x7.5 +22 wheels with a 215/40/17 tire. I have Z brakes so im pretty sure it wont clear (wheels are still on order so dont have a clue at the time) and I want them to be pretty flush. Id like to use a small spacer so i dont have to use extended studs or buy wheel adapters.
Question 1: What is the largest spacer I can use while still running the stock wheel studs? Question 2: What would mm spacer/adaptor would make the wheels fit the flushest? Thanks for any help all!!
Im starting a new trend..... shifter carts with a SR swaps...mmuuuhahahaha |
![]() Join Date: Aug 2003
get bolt on spacers, they will bolt on to your stock studs then at the end of the spacer will have another set of studs, alot safer and you can get fat ones like 25mm, but then you should get a set for the rear too.
#3 | |
![]() Join Date: Sep 2003
#5 | |
anyways.. my question is.. Is there anyone here running anything larger than a 1/4" (~6mm) spacer on stock wheel studs? |
yea thanks for all the info guys, i just need the spacer for up front, the rears are going to be perfect, 17x9.5 +22, so those will be right on the fender with a slight roll and strech of the tires, im planing on cambering out the front neways so i guess ill look into a 20-25mm bolt on spacer. ill throw some pics up in a few weeks show ya what it ended up looking like. thanks again
