S13 SR20DET CAS issue
I'm having trouble idling and accelerating. Idling is very inconsistent and the engine will eventually stop if I don't rev it up. Revving it up sounds really bad. Breaks up badly. Once up there, it'll run ok, but getting up there sounds bad.
Running stock ECU. I checked the diagnostic LED and got code 11, which is the CAS code. Checked CAS wiring. 12V feed is good. Ground is good. 180 Deg signal to ECU is good. 1 Deg signal to ECU is good. Thought it was the CAS itself so I pulled the CAS and found that both the 180 Deg and the 1 Deg signals were sending square waves with voltages ranging from 0.3 to 5.2 volts, which seems good. Timing was set correctly. So I am at a loss as far as what might be going on. I think it's unlikely, but I suspect: - Grounding issue - Bad MAF and ECU is just getting confused and throwing the 11 code - Bad O2 sensor and ECU is also getting confused Appreciate any input |
I’d find a local with a known good MAF and try that. Sure you have fuel/ignition on all cylinders?
![]() Join Date: Jul 2005
boost leak test, pressure test, OEM maf plumbing, rule out the maf
Rev the engine without maf connected -> Revs fine = problem is maf (only revs to 2500 or something but its clean) |
