Old 10-03-2022, 08:24 PM   #1
shuiyuan
shuiyuan is an unknown quantity at this point
Exclamation Help! 90 S13 stall after 2-3 mins drive wont start again Video*
I really need help! my 90 240sx has an issue, it will ran good for 1-3 minutes then start bogging and stall, push gas pedal wont make the RPM go up, it will stall no matter what.
The funny thing is i can leave the car idle for 1 hour without any issues , idles smooth, if i drive it, it will stall in about 2-3 mins and i wont start up again and i attached a video. if i wait 1 hour it will start up fine.
car has new fuel pump(my fuel level sensor is not working and i put 5 gallon gas in the tank before starting the car), new spark plugs,
i did a lot search and a lots people mentioned might be a MAF sensor issues, i unplugged it ,it still wont start back up
https://youtu.be/GLvrP8Rablw
shuiyuan is offline   Reply With Quote
Old 10-04-2022, 02:54 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
FAST
Fuel
Air
Spark
Timing
When the car wont start, you need to figure out which one of these is the failure.
Does fuel pressure go away? Do you still have spark? Go do some testing and report back!
Old 10-09-2022, 10:36 AM   #3
shuiyuan
FAST
Fuel
Air
Spark
Timing
Thanks a lot for your help, it turns out no gas in my tank and gas level sensor doesnt work
now its running on 3 cylinders , i tested the resistance it shows 13 oms i think it might be clogged, i had all 4 plugs, ordering spark plugs wires just in case
Old 10-05-2022, 07:07 AM   #4
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
Could be the fuel filter.
OnTheChip is offline   Reply With Quote
Old 10-08-2022, 10:27 PM   #5
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
Did this get resolved? If not I had a very similar problem years ago, when it stalls out, unplug you coolant temp sensor and try to start it, if it starts right up, that’s what it is
Mishkin_707 is offline   Reply With Quote
Old 10-09-2022, 10:33 AM   #6
shuiyuan
Originally Posted by Mishkin_707 View Post
Did this get resolved? If not I had a very similar problem years ago, when it stalls out, unplug you coolant temp sensor and try to start it, if it starts right up, that?s what it is
mine turns out to no gas in the tank, and my gas gauge sensor is not working(im using D21 fuel sending unit, the floater sensor works but tanks are different height)
