![]() Join Date: Jan 2013
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
![]() $13,400 OBO
NO TRADES. I want less cars. Link to photos: https://photos.app.goo.gl/ACW5DDeqsFfoEn1e9 Putting my 1993 Nissan 240sx Coupe up for sale. I just don't have the time for it anymore. I wanted to get it up to snuff with my S14, but that's not gonna happen any time soon. Super clean chassis, strong motor, and impeccable interior for an s13. Working heads up display, only one crack on dash, complete center console. The first things I'd address on the car are new brake pads, boost leak, and rip out the alpine security system from the 90's. Has power windows, mirrors, and locks. The car is a hoot to drive. List of mods: Turbo was added in 2009. Boost controller set up, off is 5lbs, on low boost is 10.5lbs 10.5lbs made 282 rwhp/287 ft/lb torque. JWT tune is very rich, easily 30 more hp in it with fine tuning. KA is around 95k miles Mods: Exterior Modifications: Bomex AD-026 bumper Nissan JDM Clear/Amber bumper lights S13 Silvia front end conversion w/ Triple projector headlights Seibon OEM-Style Carbon Fiber Hood SilviaParts.com Carbon Fiber GT-R style grille Silvia trunk emblem Security Alarm w/ remote entry SPARCO Hood Pins Engine Modifications: 95 KA24DE engine 3 inch Catco High Flow Catalytic Converter or 3 inch Test pipe ASP lightened crank pulley Gauges - Autometer Phantom series- Water Temp, Oil Pressure, Oil Temp, EGT, and Boost Dual Altima Electrical Fans w/ Dual Switches Koyo Aluminum Radiator Polyurethane filled Engine mounts Battery relocation to Trunk Tanabe Super Madallion Racing Spec cat-back Walbro 255lph fuel pump CS coolant resevior Megan Racing BMC heat shield Blue Univerasal catch can Alum under engine tray Heat reflectant applied to BMC heat shield and underside of hood Turbo parts: JWT ECU with Cobra maf and S15 480cc injectors Nismo FPR Greddy Nismo FPR swivel adapter Earl's liquid filled FP gauge and inline 1/8 NPT adapter - from SummitRacing SSAC manifold (runners cut and plained by Joel at HRT) GT32e .60/.63 - from Eric at turbotime 3" DP with V-band and flex sections JGS T3/T4 turbo oil kit (replaced sending line with 4' and 18" ones with them T'd at passenger strut tower) OEM Z31 turbo gasket and OEM Z31 locking tabs Tial 40mm WG, open dump tube HKS SSQV FMIC - from Johnny Racer Greddy Profec Type S Drivetrain/Transmission Modifications: Fidanza Lightened Flywheel ACT HD street disc 1 piece Shaftmasters Alum Driveshaft Kaaz 2-Way Limited Slip Differential OEM finned Diff cover OBX Short Shifter Polyurethane filled Transmission mount Wheel and Tire Modifications: 17x9 +12 Rota P45R Sport Bronze 2 x Nexen 3000 235/45/17 2 x Falken Pro G4 A/S 235/45/17 Suspension Modifications: D2 Racing coilovers - 9/7 spring rate Camber plates (front)/Pillowball mount(rear) SPL solid alum subframe bushings SPL Adjustable Front Lower Control arms NISMO Power Brace ProjectSilvia Adjustable front Tension rods R32 Skyline Rear Anti-sway bar (26mm) Tanabe Rear Upper Control Arms Tanabe Sustec Front Anti-sway bar (30.4mm) Whiteline Aluminum Rear Strut Tower Bar Intense Power Adj Toe rods Intense Power Adj Traction rods Brake Modifications: ProjectSilvia Steel Braided/Teflon coated Brake Lines (Front) SPL Parts Steel Braided/Teflon coasted Brake Lines (Rear) Z32 30mm Brembo Rotors (Front) Z32 30mm Calipers (Front) Hawk HPS pads all around Z32 (17/16) 300ZX Master Brake Cylinder Interior Modifications: Z33 black cloth seats in front S14 rear seats D2 Racing quick release hub LTB 20mm spacer NRG Steering wheel deep dish RedlineGoods.com Leather Shift/E-Brake boots (Black/Red stitching) Import Intelligence White Face Gauge Overlays SPARCO Corsa Pedal Set Audio Modifications: Kenwood Bluetooth Head unit Sony Xplode 6 1/2 inch speakers (4) |
Does not have functioning AC, but still has functional blower motor in dash, and heat. I'm, actually, thinking the boost solenoid for the greddy boost controller might be going bad. Haven't had the time to just bypass it and run waste gate pressure to make sure, though.
