Old 03-18-2002, 06:18 PM   #1
240sxxx
240sxxx is an unknown quantity at this point
i installed a new clutch this weekend and now when i press the clutch i hear a loud squealing from there. the pedal is also extremely light, but it seems to engage and disengage normally.
any ideas?
240sxxx is offline   Reply With Quote
Old 03-21-2002, 03:44 PM   #2
jonsey
jonsey is an unknown quantity at this point
Did you put in a new bearings?  Pilot and Throw out,
When I changed my clutch, I didn't chage the bearins and I get a weird kind of noise too, but if it isn't shaking or not disenganging properly you are probably fine.
It might just need some grease.
Good Luck
jonsey is offline   Reply With Quote
Old 03-21-2002, 09:58 PM   #3
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
does it make a grinding like noise when you depress the pedal enough to cause the throw out bearing to ride against the pressure plate? if so then its your throw out bearing. did you apply white litium grease on your shaft? (no pun intended <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>)
if this doesnt apply post back with some more info and i'll see what i can think of.
also did you resurface your flywheel? it could be glazed or you could have gotten some grease on the clutch surface causeing it to squek due to the grease
hope this helps
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline   Reply With Quote
