Old 01-07-2005, 01:22 AM   #1
luckie2hav3her
luckie2hav3her is an unknown quantity at this point
Send a message via AIM to luckie2hav3her
bad thermostat blew upper radiator hose
as soon as the upper radiator hose popped the car turned off, is there any serious damage that couldve happened to my sr?? im thinking that i just either blew the headgasket and or warped the head.... if so im planning on replacing the head and headgasket... if i get a new head and change it will it run the same?? or is the car even worth trying to fix?? honestly i need opinions on this..... fuckin piece of shit thermostat, i live in so cal i dont even need that shit!!!
luckie2hav3her is offline   Reply With Quote
Old 01-07-2005, 03:02 AM   #2
ALTRNTV
If you blew the headgasket, chances are you warped your head also. Check inside to see what's damaged.
ALTRNTV is offline   Reply With Quote
Old 01-07-2005, 07:27 AM   #3
The Hamsterball
The Hamsterball's Avatar
The Hamsterball is making a name for him/her selfThe Hamsterball is making a name for him/her self
replace the thermostat and your hose.
Run the engine. See if it feels different.
It takes a lot to warp a motor (even if it overheats)..
My car used to have overheating problems too. It used to go close to the H, and then back down after turning the heater on, and driving the car (really slowly.. to let air blow on the radiator). It was my thermostat and I never bothered to replace because i was lazy lol.
one day my radiator blew after a hard run, and the needle shot up. I turned the car off.
Replaced radiator and thermo, and to this day (3,000 miles after the event) i haven't had any problems. I can say it used to overheat once a week (on hot days only) for a few months.. lol, when i was on my test drive to buy the car, it blew a radiator hose too.
But i feel that if your engine just stalled after it overheated, it might (MIGHT) be worse.
How long did you let it overheat (immediate timewise. meaning, how long was the needle on Hot?)
How far did the needle go? Past the red? or just below the H and stay up for a while?
When it shot up, you didn't continue to drive it did you?
Anyways, of course you can do the usual compression test as well.
So just replace those two parts (it should be like $10 to replace both) and check it out.
White '90 S13 Fastback (SOLD in '07)
The Hamsterball is offline   Reply With Quote
Old 01-07-2005, 09:48 AM   #4
kandyflip445
kandyflip445's Avatar
Replace the hose and make sure you have it on all the way with a good clamp. Do a compression test like this other guy said.
Wtf, is up with saying you don't need the thermostat.....you were joking right?
My 240 vBgarage
Old 01-07-2005, 02:38 PM   #5
luckie2hav3her
once my upper hose popped the car turned off and i didnt even try turning it back on, i took it to phase2 and they ran a compression test, it was bringing out low #'s like 80, 70... the guy told me that it was suppose to be reading at like 150, i dont kno wat type of units those #'s were but thats wat he read off this gauge he was using.... and yea i wasnt kidding about taking off the thermostat, u dont need it, its only there to heat up the air u use for ur heater
Old 01-07-2005, 02:41 PM   #6
Var
Var's Avatar
Send a message via AIM to Var
you learn something new every day
you're talking about the heater core, although the thermostat being there does help the water heat up faster so technically you'd be able to use the heater quicker with a thermostat
Hi
Old 01-07-2005, 03:18 PM   #7
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
What are you stupid?? It’s there to maintain proper engine tempter w/ out a thermostat water isn’t in your radiator long enough to cool down properly so depending on the weather you could be running to hot or to cold never will you have a normal running tempter and god forbid its a hot day on a sr witch is already known for running hot but go ahead dude it's your car just don't go telling other people that its okay to do it.
driftyour40 is offline   Reply With Quote
Old 01-07-2005, 03:15 PM   #8
kandyflip445
The thermostat is the device that lets your engine stay at its operating temperature in conjunction with the other cooling devices. In other words. YOU NEED IT.
My 240 vBgarage
