![]() Join Date: Nov 2003
Battery relocation wiring Q
Hi guys, I relocated my battery to the trunk a few weeks ago.. was in a rush because I was putting in my FMIC.. anyhow, I did it the super ghetto way, just put a ring terminal on some Home Depot super stiff 2 gauge wire, and hooked it up to the thing that goes on the positive on the battery. Grounded the battery to the trunk floor.
I did some searching and some people put the positive lead on the starter.. is this correct? What about all the other stuff like the black and green plug (that plugs into the big red plug) that touches the positive? Please bear with me as I have very little wiring knowledge. Thanks ![]() |
![]() Join Date: Dec 2002
Bolt the lead from the battery to the starter.
Then either insulate the battery terminal and tuck it away, or tie it all together somehow at the terminal.
![]() Join Date: Apr 2002
I haven't finished mine yet. I've the battery box mounted for 6 months empty...ha!
Anyway, I'm planning on using one these things. Hopefully it will make it easier to clean things up http://img.photobucket.com/albums/v3...r/000_0204.jpg
89 S13 hatch/////98 Subaru 2.5RS |
![]() Join Date: May 2003
What's crazy is you didn't take out your battery box, you just cut right the sucker.
I removed my battery box and it was a biatch...
- Jay ![]() WTB: Nothing at the moment. LEWL WTS: Everything sold, thanks folks! |
#5 | |
#6 | |
#7 | |
#8 | |
Battery power flows to the starter terminal. The positive terminal lead to the starter is still there as well. Power flows through the terminals on the starter up to the battery terminal. Power flows through the terminal to the fusebox.
#9 | |
Is there an advantage to bolting the lead from the battery to the starter, rather than bolting it to the oem lead that was originally attached to the battery? I'm in the middle of my battery relocation and am a little confused about this recommendation...
![]() Join Date: May 2005
my pos. lead is rigged to the original lead for now. i'm going to either run it to the starter or pick up a distribution block. i'm not leaving it where it is now, it just doesn't look very clean
#12 | |
#14 |
I know this is an old thread. I searched and looked at a bunch of other threads but didn't find an answer to my question. I'm just wondering about the gases that batteries emit. If I buy an optima and relocate it to the trunk without a battery box should I worry about this? My car is a daily driver. Thanks!
#15 |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
with an optima you should not have a problem and as long is the car is not a hatch and has a back seat you dont need an externally vented battery box
always use a battery box shit the marine ones are under 20 at any auto parts store if you are being totally cheap use that
I never knew you could do that with an eggplant |
#16 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
hatch or not, any trunk mounted battery that is not a 'dry/gel' cell needs to be vented. Your trunk is hardly air tight even in a coupe.
Regardless if you know people without problems, it's not safe.
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
#17 |
safe or not I am just saying that for teh drag strip if it is in hte trunk and you have a rear seat in a coupe it is legal
#18 | |
![]() Join Date: Jul 2001
#19 |
Optimas are gel cells, they don't need to vent and you can mount them upside down if you want.
Standard sealed type batteries require venting, even if it's in the trunk.
#20 | |
#22 | |
the reasoning behind this is it protects the terminals from grounding to the chassis in an accident if the batt breaks loose from its mountings electrical fires are bad and this helps to prevent them
#23 |
easiest way to bolt the + lead to the harness is with a bolt/nut and washer. you put a washer on each side of the existing harness terminal, then send a bolt through the new + terminal and a bolt on the other side and tighten it all up, walla... done. id get a pic but im tired and lazy...
No Signatures over 400x200!! |
#24 |
Just out of curiousity where did you ground your battery in the trunk?
91' hatch RedHead SR20DET Apex-i N1 Cat Back HKS Downpipe Blitz LM FMIC Sr20detperf Hot Pipe HKS SSQ Apex-i Intake Rays 77w 17x8 Eibach sportline Tokico Illumina |
#25 | |
cutting out the oem battery tray is a pain. I took to it with a crowbar, sawzall and hammer. a drill is a good idea to break apart the annoying parts. |
#26 | |
one of the teachers in the automotive program at my school, the teacher for electrical systems, told me that gel cells do indeed create the same gases as normal batteries, so a vented box is still a good idea.
and just to have correct terminology, power doesn't flow, current flows through wiring diagrams.
#27 |
My system is wired to the original leads using a 150 amp marine circut breaker it works great and gives me aa handy place to power down the car when i put it in storage.
#28 | |
