Old 01-20-2005, 10:45 AM   #1
RedlineRacer
RedlineRacer is an unknown quantity at this point
Send a message via ICQ to RedlineRacer Send a message via AIM to RedlineRacer
KA Air leak around my intake manifold
I've got a small air leak somewhere around my intake manifold. I can't put my finger on it, but I can hear it when it is idling, and it has a horrible idle. If if sits at idle long enough it will cut off. I've had the problem for a long time, and I realized one of my vacuum hoses was shot on my EGR. So I removed the whole EGR and capped it off. And capped of the hoses for it. But, the problem was still there and now it is getting worse. Please help if you can. Thanks.
RedlineRacer is offline   Reply With Quote
Old 01-21-2005, 11:45 AM   #2
RedlineRacer
any help?......
Old 01-21-2005, 01:09 PM   #3
fastpace
fastpace is an unknown quantity at this point
sounds like you still have a vacuum leak somewhere. I would suggest looking all over the engine bay for more vacuum leaks or you can go to this site: http://www.vfaq.com/mods/ICtester.html and make a homemade leak tester to better pen point the problem.
life is what you make of it!!!!
"well, I go out, I do the practice, I think about it and I concentrate on one small thing I can change that will have an effect. I make that change then I go out and drive to my maximum." -Ayrton Senna
fastpace is offline   Reply With Quote
Old 01-21-2005, 04:03 PM   #4
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Or just spray carb cleaner around the area and when the idle rises you know you've found your leak.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
