So today my car decides it wont go in reverse. I'm taking it to the transmission place on monday. its a 90' auto. do you guys think i should do a 5-speed swap since i already need a new transmission? Do i need to change anything with the ECU? thanks
-Brian |
Make sure you got enough fluid in it. I have seen problems like yours when a trans doesnt have enough fluid in it. If I were you though I would swap in a five speed anyways if you got the money for it.
91 Fastback SE |
I hate you too...
![]() Join Date: Jul 2001
If something. Anything. If it breaks, upgrade it. Then tell yourself it was cheaper. Think about this.
New auto tranny = $1500 Used manual tranny = $300 Misc manual parts = $400 Labor = $300 So there. You have saved money over a new tranny. Just dont think about the whole: Used auto tranny = $300 Labor = $150 This is a great was to establish cognitive dissonance. Removing your mind from a situation. -Jeff
Whatup? |
![]() Join Date: Mar 2002
I just pulled a 91 ka for a sr swap and it was a 5 speed tranny and I will let it go for $300 if you are interested
'91 hatch w/ SR Sold; '03 Evo Sold 401 HP; '03 MS Protege sold; '00 Evo 6.5 TME Sold 300HP |
![]() Join Date: Jun 2001
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Jeff240sx @ Mar. 24 2002,03:22)</td></tr><tr><td id="QUOTE">If something. Anything. If it breaks, upgrade it. Then tell yourself it was cheaper.</td></tr></table><span id='postcolor'>
Isn't that a great way to do it? I did the same thing with my exhaust. New OE exhaust: 200 dollars labor: 30 dollars Replacements because of rust, multiply above by 3. New Performance stainless steel exhaust: 517 dollars Labor: 30 dollars Savings because of quality construction: 143 dollars <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=' ![]()
Learn everything you can, while you still have the chance. |
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Jeff240sx @ Mar. 24 2002,03:22)</td></tr><tr><td id="QUOTE">If something. Anything. If it breaks, upgrade it. Then tell yourself it was cheaper. Think about this.
New auto tranny = $1500 Used manual tranny = $300 Misc manual parts = $400 Labor = $300 So there. You have saved money over a new tranny. Just dont think about the whole: Used auto tranny = $300 Labor = $150 This is a great was to establish cognitive dissonance. Removing your mind from a situation. -Jeff</td></tr></table><span id='postcolor'> Sure has a way of putting things into perspective... Turbo for KA $3000 Look On Other Guys Face When You Destroy Him, Priceless!
In case you do go 5 speed swap
Here is a list of things you need: Manual Transmission Shifter Release Bearing Pressure plate Clutch Flywheel from a m/t M/T Mounting plate Flywheel Bolts (m/t bolts are longer than a/t bolts) Clutch pedal Brake pedal (From M/T car) or you can cut the auto brake pedel down. Clutch master cylinder w/ resevoir Clutch slave cylinder Clutch hydraulic lines (Main line, bleeder line, rubber line to slave cylinder) Drive shaft front & rear section Adapter bolts & nuts for mounting crossmember to the 5 speed (2) Reverse light sensor, Neutral position sensor, 5th gear sensor (on side of 5 speed) lower shift boot & plate Upper Shift boot & Finisher plate. |
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
hey Omar you taking lessons from me?hahhaha thanks for saving me some typing <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt='
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
Trans from SOHC and DOHC are the same. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt='
![]() <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'> |
