Old 02-19-2005, 06:36 AM   #1
coptic
coptic is an unknown quantity at this point
I Did It Again! Stupid Bolt!
Yeah, I did it again , I sheared the head of of the bolt that holds the caliper to the bracket on the rear brake of the 240. I got the other bolt off fine, but the head just snapped on this one. Anyone have a ny tricks for getting the last of the caliper off so that I can hopefully do some brakework? I have already staurated the bolt (which is flush with the caliper-DANG) with a generous amoount of PB Blaster lubricant. PLEASE I NEED HELP!!!
coptic is offline   Reply With Quote
Old 02-19-2005, 06:46 AM   #2
ILiveToDrift
ILiveToDrift's Avatar
ILiveToDrift is an unknown quantity at this point
so theres no head to the bolt? So theres nothign to grab onto? My solution would be drill it out. But sweet jesus is that even posible on that bolt? Its a hefty one isnt it?
ILiveToDrift is offline   Reply With Quote
Old 02-19-2005, 08:02 AM   #3
Campos
Campos's Avatar
Campos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura aboutCampos has a spectacular aura about
Send a message via AIM to Campos
that bolt comes in from the back right? the only thing i can thnks of is disconnect the brake line, and remove the whole deal and take it to a machine shop, they should be able to help you. they usually charge around $15 for that kinda stuff. good-luck
Parting out SR build....
Campos is offline   Reply With Quote
Old 02-22-2005, 05:40 AM   #4
coptic
thanks guys, thank God I finally got it out
Old 02-22-2005, 09:05 AM   #5
dizastaman
dizastaman's Avatar
dizastaman will become famous soon enoughdizastaman will become famous soon enoughdizastaman will become famous soon enoughdizastaman will become famous soon enough
lol i did the same thing on mine, trying to change the pads. i got pissed and just cut the caliper off and bought a new one. easy fix!
My FLICK-argh page
dizastaman is offline   Reply With Quote
Old 02-23-2005, 12:47 AM   #6
s13gonwild
s13gonwild is an unknown quantity at this point
how did you fix it? you should post up what you did for future refrence, so people can search and get the awnser instead of making a new thread.
s13gonwild is offline   Reply With Quote
Old 02-23-2005, 08:04 AM   #7
coptic
okay, i basically took the entire substructure off, i.e. everything offof the drive shaft , drilled out what I could of the bolt and then physically beat the rotor of of the bolts and the bracket just popped off thank God. I just had to get a new braket because I think that I might have messed up the thread
