Old 03-24-2005, 11:08 PM   #1
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
Fuel pump re wire HELP
I need a re-wrie write up for a redtop SR and a walbro 255. i need to rewire with 10 ga and i have no idea what to do. i know i need a 30 amp relay and fuse. and i have part numbers. but i dunno how to actually do it. my battery is in my trunk so i was hopinh i could use a foot of wire and hard wire it. but then the pump would be on all the time. i want it off when the car is off. anyone know where i can see how to do this.
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 03-25-2005, 03:22 AM   #2
s13silady
s13silady's Avatar
s13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfections13silady is close to perfection
there was a thread i did a while back...cant seem to find it but here...
Relay in trunk near fuel pump.
10-12ga. power wire direct from battery to input on relay.
Stock fuel pump power wire to + trigger on relay
Ground - (neg.) trigger and neg pole of relay to chassis
Stock fuel pump power will flip the relay, which in turn will power the fuel pump directly from the battery.
Worst case scenario and you blow the relay, just reconnect the stock wires and call it a day.
ENTHALPY on here should have a more descriptive write up, but i cant seem to find it... but then again... im too lazy to do your own work...
ANSWER
s13silady is offline   Reply With Quote
Old 03-25-2005, 08:08 AM   #3
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Whats the benefit of doing this anyway? Ive heard it spoken of before
wootwoot is offline   Reply With Quote
Old 03-25-2005, 10:10 AM   #4
orion::S14
orion::S14's Avatar
The higher elec load of a big fuel pump can't be supported by the stock wiring, especially on ~15 year old S13s.
This will insure the pump can flow what it's supposed to...fuel pump flow is directly related to the voltage it recieves.
- Brian
www.KA24DEvelopment.com
Old 03-25-2005, 12:31 PM   #5
s13dan
s13dan's Avatar
my 255lph is prolly a 190lph right now.. and thanx silady
Old 03-25-2005, 04:27 PM   #6
s13silady
s13silady's Avatar
np... yah you cant really really feel a difference... but at least your at ease knowing that your getting enough fuel... but iirc.. i dont think the stock injectors flow past a certain amount though... not for sure though... elaboration anyone?
