Old 04-01-2005, 03:04 AM   #1
sw20>>s14
sw20>>s14's Avatar
POS! better not be what i think it is...
replaced my water pump and it still overheated. its because i half ass bled the system. so overheating is not the problem. but the next night, i move my car and pop the hood to make sure everything is cool and leak free. i see little fresh beads of honey/oil like substance on the gasket. this is what it looked like today dried:
i look above and the valve cover is cool because i just replaced that gasket. why does it look like oil is somehow squeezing past the gasket and rtv? why is oil there in the first place? possible... ... bad... ... head gasket? say it aint so, say it aint so... any help identifying the problem would be greatly appreciated...
sw20>>s14 is offline   Reply With Quote
Old 04-01-2005, 03:31 AM   #2
kandyflip445
kandyflip445's Avatar
If there is oil in your coolant you could easily check by opening the rad. cap. Or by checking the dipstick to see if it's milky.
My 240 vBgarage
Old 04-01-2005, 03:45 AM   #3
sw20>>s14
sw20>>s14's Avatar
saw the dipstick in a quick glimpse when my friend checked it and it didnt look milky. he didnt mention anything out of the ordinary either...the last thing i need is more down time...
Old 04-01-2005, 04:04 AM   #4
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
lol milky oils suck serious downtime u have to wait a day or 2 if its just sittin
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 04-01-2005, 07:07 AM   #5
jdmsilvia909
jdmsilvia909's Avatar
jdmsilvia909 is an unknown quantity at this point
theres a possability you might have to replace the front cover as well
*Image(s) exceed(s) forum limit, strike 2*
-Moderation
R.I.P. 1990 NISSAN 240SX...U WILL NOT BE FORGOTTEN
jdmsilvia909 is offline   Reply With Quote
Old 04-01-2005, 08:18 AM   #6
Titan
Titan is an unknown quantity at this point
Are you certain it's oil?
If it's dried up, I highly doubt it's oil. Looks like it's just leaking coolant.
Pull the pump off, clean the mating surfaces, and reseal it with RTV.
Sleep Doesn't Drink Beer
Titan is offline   Reply With Quote
Old 04-01-2005, 05:29 PM   #7
sw20>>s14
sw20>>s14's Avatar
it looks as if though it is leaking from the pump side of the gasket. my parts guy made it a point to tell me to put really little rtv on the block side of the gasket. could it be that i didnt put rtv on both sides? or do i just suck at RTVin'? theoretically, i didnt even need rtv because of the gasket right? so if i took the extra measure of adding a sealant, why would the gasket and rtv fail? thanks for the advise...
Old 04-01-2005, 05:30 PM   #8
S14DB
AFC #1
S14DB's Avatar
Did you wait for the RTV to set before presurizing the system?
Old 04-01-2005, 05:45 PM   #9
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
alternative to rtv is permatex, which is an "aviation" gasket sealant. its hella gooey, hella messy, but hella stronger. rtv works better if mating surfaces are crappy. permatex will hold more pressure and is more heat resistant compared to rtv.
ultraDorksGarage is offline   Reply With Quote
Old 04-01-2005, 05:50 PM   #10
SimpleSexy180
did you also scrap off the existing gasket that usually sticks to the block?
SimpleSexy180 is offline   Reply With Quote
Old 04-01-2005, 06:00 PM   #11
sw20>>s14
sw20>>s14's Avatar
for the most part yes. i waited about maybe four to five hours, but not the full 24. should i redo?
yeah, the best i could, but i read that you shouldnt scrape the block with any sharp/blade like objects because chunks would come off, so i just scraped it with my fingernail. thinks its not good enough?
Old 04-01-2005, 06:12 PM   #12
ultraDorksGarage
no... razor blade scrapers, yes please
Old 04-01-2005, 08:01 PM   #13
SimpleSexy180
well it just has to feel pretty smooth enough so it doesnt create bumps and gaps.
