Old 04-09-2005, 02:21 PM   #1
dreamer
dreamer is an unknown quantity at this point
my drivetrain shakes a lot in 1st and 2nd.. help?
so i just swapped out a ka24e automatic and dropped in a ka24de 5spd... and when i drive it in 1st and 2nd gear, in the low rpm range (i dont know exactly because my tach doesnt work) the shifter shakes slightly, then more and more violently... and then i hear/feel some thing bumping against the underside of the car... i'm assuming its the transmission or driveshaft or something of the like.
anyone know what it could be? i dont think its a tranny mount and i think my driveshaft should be balanced... but what could possibly cause this?
also, my tach doesnt work. anyone ever had a tach stop working on them? i swapped in a DOHC gauge cluster with the motor.. first time i started it, the tach jumped from 0 to 1500......... then never moved again lol
dreamer is offline   Reply With Quote
Old 04-09-2005, 03:47 PM   #2
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
the driveshafts sound like they're not the same length, and are under load. you might need to seperate the half-shafts and put your auto rear half shaft + manual front halfshaft.
dohc cluster is not the same as the sohc.
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 04-09-2005, 04:02 PM   #3
SimpleSexy180
if it bouncing up and down and shaking, its probably your transmission mount, plz check.
SimpleSexy180 is offline   Reply With Quote
Old 04-09-2005, 04:05 PM   #4
ThE_BoMB
ThE_BoMB is an unknown quantity at this point
Send a message via ICQ to ThE_BoMB
I also agree that it sounds like the tranny bushing. Did you reuse your ka24e bushing and not replace it >? i would replace that first.
if it still happens after that then tell us and we shall go from there.
1991 240SX SE
I dont have any mods i swear!
http://www.cardomain.com/id/the_bomb
ThE_BoMB is offline   Reply With Quote
Old 04-09-2005, 06:36 PM   #5
projectRDM
projectRDM's Avatar
Make sure the paint mark on the back of the driveshaft lines up with the mark on the diff to get it close to balanced.
FORMERLY R240NA
Old 04-09-2005, 06:38 PM   #6
dreamer
^ the auto and manual driveshafts are completely different. the halves are different lengths/sizes... so if i mixed it , it wouldnt fit up right.
and yeah i replaced the sohc cluster with dohc because the sohc tach doesnt work with the dohc motor... but .. apparently neither does the dohc tach
i did not change the mounts or bushings. i dont know much about the drivetrain so im gunna have someone more knowledgable look at it or take it to a shop and see what they say ... when i have money... haha cuz right now i cant afford to take it to jiffy lube
Old 04-09-2005, 09:16 PM   #7
EchoOfSilence
actually the front halves should be the exact same length, but the rear halves are different lengths.
Old 04-11-2005, 04:27 PM   #8
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
multishaft setups are balanced together, changing/mismatching propelor shafts will be f@cked. most even have a sticker on the shaft that u must replace both sides or have rebalanced.
ultraDorksGarage is offline   Reply With Quote
Old 04-11-2005, 01:34 PM   #9
my240iguanas
my240iguanas is an unknown quantity at this point
Send a message via AIM to my240iguanas
I had the same prob , my new tranny mount bushing was $75 from the dealer
my240iguanas is offline   Reply With Quote
Old 04-11-2005, 02:56 PM   #10
NemeGuero
No more nissan.
NemeGuero's Avatar
you're wrong echo, the front half is the one that is different sizes from auto to manual
rear halves only vary from ABS to non-ABS as long as it's the same chassis
Old 04-11-2005, 03:00 PM   #11
s14 blacktop
s14 blacktop is an unknown quantity at this point
Send a message via AIM to s14 blacktop Send a message via MSN to s14 blacktop Send a message via Yahoo to s14 blacktop
^^this does not matter, I put and took mine off several times and the marks are not lined up and it works fine... no vibrations whatsoever...
I'm here to inform not to conform...
s14 blacktop is offline   Reply With Quote
Old 04-11-2005, 04:31 PM   #12
ultraDorksGarage
the other thing is propellor shaft imbalance/length is proportionate to wheel speed, not ENGINE speed...so like the others said check ur tranny mount first, as well as motor mounts^^
Old 04-11-2005, 04:34 PM   #13
NemeGuero
No more nissan.
NemeGuero's Avatar
he said that 'cuz when we did my swap, we ended up HAVING to mismatch my DS.. s14manual front, s14 auto rear.. I got no problems. I had the same vibration using the entire s14 manual DS.. I think the rear section was ABS 'cuz the fit was too tight.. i had to put in the front, rear.. and then push the center up until it 'locked in'
Me N Echo tag team tranny questions! Haha
Old 04-11-2005, 04:44 PM   #14
ultraDorksGarage
working with multishaft propellor setups at work id agree that the marks matter... maybe on a short setup like a s13 it wont, but u should still put it back the way it was balanced as.
do u switch main journal caps around even though they have been line honed and marked? perhaps things worked out fine, but the idea of balancing is to negate bad forces(reduce wear on bearings/bushings), which u prolly cant feel. perhaps im too critical having worked with propellor shafts in 6 foot lengths, but still, put it back the way it was balanced.
Old 04-17-2005, 12:21 AM   #15
dreamer
the driveshaft was unbalanced... the bolts in the propeller shaft were mis-matched. ....anyone have any idea as to fixing the tach?
Old 04-17-2005, 12:33 AM   #16
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Yup driveshaft not balanced and it could have esily been out of phase...Mark it before taking it apart it saves the hasle.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
