![]() Join Date: May 2002
s14 needs at least
MEGA pull (a good 20mm at least) and some nice meaty camber or a slight pulol lots of camber stretched tires s13.wide fenders unless oyur master of body work some might dump the fuck out of the camber but thats useless. go wide fenders is best but s14 is more likely an easy fit. s13 just wide fender it 10.5 +15 is a good size for s14 with wide fenders. very good size. very common match it with some 9.5 +12 up front! ![]() |
it will fit fine, but only with a good roll and pull with an eastwood fender roller. also plan on your paint cracking in the process of rolling/puling so plan on getting paint. or you could kist go 10 inch 12 offset... less work, still looks good.
![]() +0 offset PWNS me |
Sorry forgot to mention, these are for an s14 model.
Hy dousan thanx for your input. I'm thinking the 10.5 and 9.5 in front will be ideal. I'm probably not going to pull the fender, but instead have some custom body (bondo work) done. nigel1, I can say from experience that what you say is true, thanks for the heads up. |
