Old 04-17-2005, 10:57 PM   #1
9524tee
9524tee is an unknown quantity at this point
Send a message via AIM to 9524tee
s14 nismo motor and tranny mounts ....
yes i searched , could not get a straight answer from anything i looked at . so i decided to start this thread .... i have an auto s14 with a ka , im doing the 5 speed swap , and at the same time i am replacing my motor mounts , will the nismo motor and tranny mounts work , with a direct bolt on approach ? thanks .
9524tee is offline
Old 04-17-2005, 10:58 PM   #2
kandyflip445
kandyflip445's Avatar
Yes they will work. You have to switch the motor mounts.
My 240 vBgarage
kandyflip445 is offline
Old 04-17-2005, 11:01 PM   #3
smithers584
smithers584 is an unknown quantity at this point
yes they will work but keep in mind they are much stiffer and if you dont like your car to vibrate a little then you dont want them. I have them in my sr equipped s14 and at iddle my rear view mirror vibrates a bit, enough to distort vision through it.
smithers584 is offline
Old 04-17-2005, 11:02 PM   #4
goodjuan
goodjuan's Avatar
goodjuan is an unknown quantity at this point
Send a message via AIM to goodjuan
i highly suggest that you save money and modify your stick mounts instead of getting the nismo ones. I actually have the nismo mounts. It was only after i had bought and installed them that I learned of filling them with urethane. I filled the mounts on my brother's car and his engine moves less than mine.
tube of window weld urethane is 12 dollars. Nismo ones are 175 or so.
3M Windo-Weld fast-curing urethane goo (part # 051135-08609) Look up an automotive paint supply store in your area and they will have this in stock. (there should be one local.) good luck man
goodjuan is offline
Old 04-17-2005, 11:07 PM   #5
9524tee
they work and they are stiffer sweet ! thats great cuz i already bought them . thanks everyone for giving me straight answers , much appreciated .
9524tee is offline
Old 04-18-2005, 08:49 AM   #6
2JZGTE
2JZGTE's Avatar
2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute
Send a message via AIM to 2JZGTE Send a message via MSN to 2JZGTE
They work great. I installed the nismo engine and tranny mounts, now my steering wheel vibrates ever so slightly at idle, but that's it. Nismo mounts are harder rubber, while eurothane is much stiffer. Nismos are a good compromise between stock mounts and eurothane.
My shifter also moves MUCH LESS now. Good luck.
Billy
R35 GT-R, R32 GT-R, Supra, S13, S14, FD3S
2JZGTE is offline
Old 05-01-2006, 05:02 PM   #7
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
Billy
Ah crap mine does that now, and I was thinking of getting nismo mounts. With those the wheel probably will fall off lol. Does yours make a sound?
s13pignose is offline
Old 05-01-2006, 05:10 PM   #8
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Awwww shit man, AGAIN, ITS FROM 1 YEAR AGO.
Neejay is offline
Old 04-19-2005, 09:24 AM   #9
importnut
importnut's Avatar
importnut is an unknown quantity at this point
I picked up my Nismo mounts to give them a shot. My 210k mounts were just horrible. They are more civilized than urethane mounts, but not enough in my opion. I have ES bushing in my civic's engine mounts, and the damn thing does NOT move. I will probably fill my Nismo mounts when I get the chance. The engine still moves too much.
So, you can save quite a bit of money and fill right off the bat, or if you've picked up Nismo mounts, you can fill those. They will probably be a little stiffer than starting with stock mounts.
People who can't handle a little vibration are =>
Also, I've contemplated welded motor mounts. It's awesome to see someone that actually did it. Totally awesome!
Here's my motor mount swap page, hope it's handy for anyone interested: Nismo Motormount Install
-Alex S.
"What about the twinkie?"
importnut is offline
Old 04-18-2005, 09:05 AM   #10
riot
riot's Avatar
riot is an unknown quantity at this point
Heh, you guys think those will make your steering wheel shake? Here are my motor mounts:
For the record, the car is only driven once or twice a week. The only annoying part is at idle...just lots of vibration. Other than that, while cruising it's not a problem.
-ryan
riot is offline
Old 04-18-2005, 09:09 AM   #11
2JZGTE
2JZGTE's Avatar
Damn Ryan, welded solid It's true though, as soon as you give it a little rev or get going from a stop all vibrations pretty much go away and the car smoothens out.
2JZGTE is offline
Old 04-18-2005, 04:41 PM   #12
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
-ryan
as a side note, another trick is to go solid on one side, this allows some vibration movement but very little radial movement.
ultraDorksGarage is offline
Old 04-18-2005, 08:50 PM   #13
The Hamsterball
The Hamsterball's Avatar
The Hamsterball is making a name for him/her selfThe Hamsterball is making a name for him/her self
Don't mean to thread jack, but...
while we're on topic... My sohc engine with 170K miles...
When I bought the car, it didn't shake as much.
As I put more miles on it... It started shaking more.
That wasn't a problem. Then one day, when I engaged the clutch at my normal 1500RPM.... the car started shaking alot.
To prevent this I either have to engage a bit faster, for less shaking...
Or engage at higher RPM and faster.
I feel the shifter shake a LOT when this shaking happens, and have a hunch that it's my transmission mount or my engine mounts.
Do you guys think it would be my mounts? They look pretty old, but I haven't gotten to see them in depth.
I'm wondering if I should try nismo mounts because I have to replace my front suspension crossmember anyways (the car's sitting on jacks).
White '90 S13 Fastback (SOLD in '07)
The Hamsterball is offline
Old 04-18-2005, 09:21 PM   #14
sLip techniques
sLip techniques's Avatar
sLip techniques is an unknown quantity at this point
if your shifter is shaking violently its the tranny mount
people on Zilvia need a big ol
sLip techniques is offline
Old 04-25-2005, 09:11 AM   #15
S14DB
AFC #1
S14DB's Avatar
-ryan
Damn, I thought I was hardcore. But, mines a DD...
S14DB is offline
Old 04-25-2005, 10:09 AM   #16
Mike Wazowski
Mike Wazowski has a little shameless behavior in the past
Cusco/Kazama mount, nice to see someone as hardcore as I am.
Mike Wazowski is offline
Old 04-27-2005, 08:34 AM   #17
importnut
importnut's Avatar
Could you provide more info on these mounts? Available for KA's?
Thanks,
Alex S.
Old 04-27-2005, 09:46 AM   #18
lilredstiffy
lilredstiffy's Avatar
lilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to alllilredstiffy is a name known to all
Send a message via ICQ to lilredstiffy Send a message via AIM to lilredstiffy
Thanks,
Alex S.
Yes they work perfectly fine on ka's.
I think phase2 and ma-motorsports both sell them
lilredstiffy is offline
Old 04-18-2005, 09:18 AM   #19
nissan_driver24
nissan_driver24's Avatar
nissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enoughnissan_driver24 will become famous soon enough
Send a message via AIM to nissan_driver24
damn crazy... solid motor mounts!!! motor mounts are made to give a lil for engine movement, and if it doesn't move it's bound to break.... i have nismo motor and tranny mount on my s13 sr20det... just get very lil vibration while at idle, i highly recommmend them and as 2JZGTE stated before my stick shift has very little movement now.....
--240sx Driver Since 2002 to 2013--
nissan_driver24 is offline
Old 04-18-2005, 11:07 AM   #20
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
shameless plug here , guys SyKo Garage is developing a set of Urethane motor mounts for KA and SR that will absolutely kick ass and not be ghetto stylie like they were made with a tube of urethane window sealant.
these are going to be the real deal mounts with nice colored urethane high quality studs.
New Video
Buy my mounts!
drift freaq is offline
Old 04-18-2005, 01:30 PM   #21
riot
riot's Avatar
I deSTROYED the stock mounts in less than a year. They had completely split in several places. I looked at several options, and one of the first options I turned down was ...paying $200+ for some "urethane" motor mounts. I'm not saying there is anything wrong with them, they just aren't worth 200 of my dollars when I can weld them myself.
-ryan
riot is offline
Old 04-18-2005, 09:44 PM   #22
vinhisbored
vinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enoughvinhisbored will become famous soon enough
Send a message via AIM to vinhisbored
When doing a 5 speed swap.. do the tranny mounts need to be replaced, or are sufficient?
vinhisbored is offline
Old 04-19-2005, 06:12 AM   #23
Dream240
Dream240's Avatar
There's only one tranny mount and yes you ALWAYS replace ALL mounts when you do a mount job. If not the old mount will cause the newer ones to wear alot faster then you need new mounts again within a year or so depending on your driving.
Dream240 is offline
Old 04-19-2005, 09:24 AM   #24
24Zero
24Zero has a spectacular aura about24Zero has a spectacular aura about24Zero has a spectacular aura about24Zero has a spectacular aura about24Zero has a spectacular aura about24Zero has a spectacular aura about
Send a message via AIM to 24Zero Send a message via Yahoo to 24Zero
the NISMO mounts gives you more NHV but work well
Jamie
My Site www.24zero.com
30D | 17-40L | 27-70L | 70-200L
Some of my work
24Zero is offline
Old 04-25-2005, 03:54 AM   #25
blk240sx
blk240sx is an unknown quantity at this point
just currious how it is that you go about to fill your stock engine mounts with urethane??
Image too large. Removed by Moderator.
blk240sx is offline
Old 04-19-2005, 05:42 AM   #26
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
theyll work and work great
sepulchral is offline
Old 04-25-2005, 04:05 AM   #27
aznpoopy
aznpoopy's Avatar
1. pull them out
2. fully clean them
3. cake them over with 3m window weld. fill in the grooves. ive heard of people using other stuff on other forums. the more you use, the stiffer they'll be. so figure out how far you want to go.
4. "officially" it takes a week to cure. i think most let them dry a day or two and then put them back in.
aznpoopy is offline
Old 04-27-2005, 09:05 AM   #28
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
Originally Posted by aznpoopy
1. pull them out
2. fully clean them
wrong. takes 2 days so solidify completely. dont have to clean, that shit sticks like nothing i ever seen. DO wear gloves, otherwise its gets stuck to skin. ANY polyurethane will work. we used cheapest we could find in home depot. was like 5-6 bux for 2 tubes, plus 2 dollar gun that broke twice.
hydropgrahics!
ls1......
420sx is offline
Old 04-27-2005, 09:58 AM   #29
aznpoopy
aznpoopy's Avatar
cleaning them is just being nice and neat with your projects... but yes it's not really necessary.
i stand corrected on the curing time though.
aznpoopy is offline
Old 04-28-2005, 01:34 AM   #30
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
ANY TUBE?
I got some PL Window Sealer that says its polyurethane...
was 3 bucks for the tube.
You guys get this stuff?
If so im gonna go do it NOW
Maeda is offline
