Old 06-06-2005, 02:27 AM   #1
chris-r
chris-r is an unknown quantity at this point
Bolt Torn in HALF & Screw Threading Bent
i was tighning a one of the 10mm bolts on my crank pully and it broke off, i guess i realsed my vengence on it lol.. but yes how do i get the broken piece out? seems dangerous to have 5 out of 6 bolts in.. also i have a nut that is stuck in place like the threading on the screw is bent all this bad luck.. please help!!
-chris
chris-r is offline   Reply With Quote
Old 06-06-2005, 03:50 AM   #2
Rezlo
Rezlo is an unknown quantity at this point
Send a message via AIM to Rezlo
Drill a small hole right in the center and use an easy-out to extract it if its countersunk in a little, remember to run a thread tap in afterwards incase it messed a few threads up. if its realy tight and wont budge take your rear main seal off and heat the crank up a little with a propane torch or somthing (nothing to hot) just get it fairly warm then use an air nossel and spray some compressed air onto the snapped off bit quick and try with the easy out again, normaly it helps it loosen up a bit.
As far as a stripped nut that wont back off, try heating it a little aswell if possible and try wedge somthing underneeth it to forse it up off the bad threads as you are undoing it or just unscrew the hole stud its screwed into cause the chances are they are dammaged
If you cant get it right go here:
http://www.highspeedperf.com/Pages/Contact/Contact.htm
Mike is the man to talk to and he is realy good at getting snapped off bolts out without damaging anything if he isnt to far from you in chicago
Rezlo is offline   Reply With Quote
Old 06-06-2005, 04:57 AM   #3
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Tap and die set. Saves time, and money.
SochBAT is offline   Reply With Quote
Old 06-06-2005, 07:03 AM   #4
Rezlo
tap and die set cant remove a snapped off bolt
