Old 06-13-2005, 01:40 AM   #1
driftcrazy
driftcrazy's Avatar
driftcrazy is an unknown quantity at this point
SR20det start up problems HELP!!!! PLZZZ
ok so we jus got done doing a s13 SR swap ina 89 240sx. everything is connected and wiring is complete. but when we went 2 start it, it would not start. there is spark, and fuel but there seems 2 be a problem with lack of vacume 2 operate the pressure regulator. so fuel is not being dipursed in the combustion. we took offf the regulator and pluged the fuel line derectly 2 the rail and started it and it start up for a bit when we would fluctuate the vacume by blocking it off. there is really low vacume form the manifold.
anybody got any clue 2 whas going on!!! cuz we don konw. all we know its a vacume issue. PLZ help we have been on this matter 4 2days now. thank you
driftcrazy is offline   Reply With Quote
Old 06-14-2005, 05:27 PM   #2
g2ic02
g2ic02 is an unknown quantity at this point
Send a message via AIM to g2ic02 Send a message via MSN to g2ic02
are you sure it isn't something dumb like the ground at the back of the valve cover.........i don't know how much vacuum you would build if your motor is just cranking over. Have you tried replacing the fpr???
g2ic02 is offline   Reply With Quote
Old 06-14-2005, 05:35 PM   #3
ultraDorksGarage
ultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura aboutultraDorksGarage has a spectacular aura about
try this...
crank over motor, when it doesnt start...
pull out a couple injector harnesses and try cranking it over, if it stumbles to life, then ur prolly got bad wirirng, causing ecu to dump fuel.
honest, try it
ultraDorksGarage is offline   Reply With Quote
Old 06-15-2005, 02:23 AM   #4
driftcrazy
driftcrazy's Avatar
thanks guys for all the ideads, but i fiugred it out, it did end up being somthing stupid tho. lol. what ended up happening was that i reversed the fuel line . so fuesl was going the way it should have came out. DHA! stupid huh. lol
but thanks yall. but do u guys know how 2 wire up a KA MAF 2 the sr harness?? is it just color matching?? or is there a certain way??
Old 06-15-2005, 08:14 AM   #5
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
polarity/color matchin on sohc maf
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 06-15-2005, 08:54 PM   #6
skiboard06
skiboard06 is an unknown quantity at this point
where is the ground on the sr on the back of the valve cover what does it look like/ is it near the head or the low part of the block where does it ground too etc thanks for ur help
skiboard06 is offline   Reply With Quote
Old 06-15-2005, 10:09 PM   #7
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
its around where the spark plug cover is, it usually connects to a spade connector where the hardline for the brake booster is.
TO the original poster, fuel pressure regulator on the return line, fuel filter on the inline.
speeddreamz is offline   Reply With Quote
