Old 06-13-2005, 10:16 PM   #1
pablo180
pablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of lightpablo180 is a glorious beacon of light
s13 SOHC to DOHC A/C question
I've just put in a S13 DOHC into my 89 coupe chassis. I'm trying to hook up the A/C and i've got everything from the 91+ chassis (compressor, condenser, hardlines, etc) the wiring is where I ran into the problem.
The plug that hooks up to the compressor is different between the SOHC/DOHC chassis.
Here's the question...will the A/C setup function properly if I cut the plug off of a 91+ chassis and solder it onto the 89 A/C wiring?
Thanks in advance,
Pablo
pablo180 is offline   Reply With Quote
Old 06-13-2005, 10:29 PM   #2
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
The fittings on the lines, from the compressor to firewall are diff. You have, to tig the de line with the sohc fitting.
TheSnail is offline   Reply With Quote
Old 06-14-2005, 09:07 AM   #3
killjoy
killjoy's Avatar
killjoy is an unknown quantity at this point
Send a message via AIM to killjoy
I think hes talking about the wires. They have diff plugs. sohc is like a square and the dohc one is oval. If the dohc one is one wire just change them out.
stolen s13
new stock non-stolen s13
killjoy is offline   Reply With Quote
Old 06-14-2005, 12:37 PM   #4
pablo180
the wires not the hardlines
Yea...i'm talking about the electrical connector. Just wanted to see if anyone has done it and had problems with it.
Thanks,
pablo
