Old 06-21-2005, 10:00 PM   #1
outerheaven2k4
outerheaven2k4 is an unknown quantity at this point
Unhappy Rear End seems "loose"
Along with a noise when braking (sounds terrible, almost like my rear brakes are about to shatter back there, don't feel it in the pedal tho). I noticed my rear end seems a little "loose". I'm due for a near complete suspension upgrade/replacement (balljoints, tie rods, es bushings, strut bars, sway bars, tension bar, etc), was just wondering what may cause the rear end to be like it is (tire pressure is normal, thread is good). *Sigh* Poor girl needs work, just turned 190thousand today ^_^
Oh snap, forgot, this is a 89 240sx coupe with out hicas.
outerheaven2k4 is offline   Reply With Quote
Old 06-21-2005, 10:03 PM   #2
aznpoopy
aznpoopy's Avatar
typically i woudl say
try installing subframe spacers
maybe rear shocks are blown
etc.
but damn 190k? most likely everything in your suspension.
Old 06-21-2005, 10:11 PM   #3
outerheaven2k4
Shocks are good ^_^
Yeah..she's old..needs a new front end (cosmetic really) too..wanna put a s13 front end..once it can run like one
Old 06-21-2005, 11:14 PM   #4
kandyflip445
kandyflip445's Avatar
Um. You have a s13 front end already. Jack the car up and put it on jackstands. Start moving stuff and see where the sound is coming from.
My 240 vBgarage
Old 06-22-2005, 12:11 PM   #5
outerheaven2k4
LOL
yeah i'll give that a try
i mean the s13 frontend without pop up lights btw
Old 06-22-2005, 02:56 PM   #6
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
eh im 200k nothing really shot just one subframe bushings... check ur subframe bushings...
so where is the noise coming from? front or rear?
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 07-29-2005, 03:05 PM   #7
dudocius
dudocius is an unknown quantity at this point
simple dude, 240s are old cars, so why not run and get an energy suspension kit, it comes with bushings for pretty much everything even for you girlfriend. install them and it will be like giving your car a full day at the spa. secondly try to score a rear sway bar from a hicas + energy suspension bushings, some subframe collars, and your rear should be more than stiff, all this for less than 200 bucks,
dudocius is offline   Reply With Quote
Old 07-29-2005, 04:15 PM   #8
240m3srt
240m3srt is an unknown quantity at this point
Speaking from personal experience, i had a similar if not the same clunking noise during braking and shifting. I installed SPL aluminum subframe bushings and the SPL aluminum diff bushings. The brake related clunk subsided but the clunk under accel, shifting, decel, is still there. I believe its in my diff. Just some food for thought.
240m3srt is offline   Reply With Quote
Old 07-29-2005, 08:44 PM   #9
$D$
$D$ is an unknown quantity at this point
^sounds like trans/engine mounts to me. the diff doesnt move inside the case, except to spin the wheels
$D$ is offline   Reply With Quote
Old 07-29-2005, 08:52 PM   #10
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
motor mounts and tranny mounts + subframe spacers.
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
