Old 04-24-2002, 08:54 AM   #1
tmerrick
tmerrick is an unknown quantity at this point
Send a message via AIM to tmerrick
yesterday I installed my greddy 52mm electronic boost gauge and the needle doesnt move. i turn on the lights and the gauge lights up but i havent been able to get the neddle to show any movement. ive got the TEE connector it came with between my intake manifold vacumme line and the fuel pressure regulator vacumme line. the hose isnt pinched and it does suck air through there. any ideas???
for the gauges wires (power, ground, illumination and 12V switched) i used the same ones that i tapped into for my cd player does this matter??
Tyler Merrick - S13 SR20DET
www.tylermerrick.com
tmerrick is offline   Reply With Quote
Old 04-24-2002, 10:26 PM   #2
bobo_80
bobo_80 is an unknown quantity at this point
blow off valve stuck open?....hehehheh <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
bobo_80 is offline   Reply With Quote
Old 04-24-2002, 11:34 PM   #3
silviasichigo
silviasichigo's Avatar
silviasichigo is an unknown quantity at this point
I have the same boost guage and the instructions I have say cut the Vacuum hose between the pressure regulator and the surge tank to install the T-pipe is that what you did? As for the wiring I would not use your stereo Just use your parking lights for the guage light that way when you turn on your light the guage light will come on. That is what I did and it works fine. Try it to see if that works.
silviasichigo is offline   Reply With Quote
