Old 10-10-2005, 07:40 PM   #1
caall99
caall99's Avatar
caall99 is an unknown quantity at this point
Send a message via AIM to caall99
Boost Spike on Homemade Ball/Spring MBC
i built my own simple adjustable boost controller from parts that i found at true value and home depot. I connected the MBC inlet with a vacuum hose to the throttle body and the outlet to the wastegate. The MBC itself is closer to the wastegate than the throttle body. In all gears it goes to 13 psi and then drops to 10 psi by 5500rpm. i haven't yet drilled a bleed to compensate for signal lock that can occur when the ball bearing comes down again. would this even affect the spiking i am experiencing? would putting a nipple on the hotpipe and connecting the MBC inlet to it help at all?
on a side note, i also noticed when i did a fourth gear pull today that the car hesistated at 6000 rpm. like it cut ignition. could this be due to the spark plug gap being too large (.043 inch)? these are BKR7EIX iridiums.
thanks guys
Signature over limits
http://www.zilvia.net/f/showthread.php?t=21036
caall99 is offline   Reply With Quote
Old 10-11-2005, 12:31 AM   #2
caall99
caall99's Avatar
i am bumping my thread cause i am an impatient bitch...
Old 10-11-2005, 02:18 AM   #3
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
I'll give you an impatient answer. Get a real boost controller(profec B spec 1), you won't regret it.
Maeda is offline   Reply With Quote
Old 10-11-2005, 04:21 AM   #4
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
That gap is too large for turbo cars. Around .032 - 0.035 or so. Re-gap and try again.
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 10-12-2005, 12:00 AM   #5
caall99
caall99's Avatar
maeda, that wasn't helpful, if i had the money i would have bought one by now. thanks, drift into a curb, i am gonna gap them down tomorrow. anyone else have any comments or suggestions on reducing boost spiking with a manual boost controller?
Old 10-12-2005, 11:19 AM   #6
caall99
caall99's Avatar
and i guess this thread is dead now...
