Old 11-01-2005, 02:09 AM   #1
KrazyZenki
KrazyZenki is making a name for him/her selfKrazyZenki is making a name for him/her self
Valve job?
Im getting my head built(cams, gears, springs, RAS, port n polish) and what I want to know is the 5 angle valve job neccessary or is just a 3 angle valve job ok? Is either one even neccessary? What are the gains and losses if any? I thought I rememeber a thread a while back saying the 5 angle valve job isnt good on the SR20 motors.
KrazyZenki is offline   Reply With Quote
Old 11-02-2005, 11:38 PM   #2
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Don't beleive what you read everywhere. Unless you are puting in some undercut/oversized valves there is no point to a 5 angle valve seat grind.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 11-03-2005, 08:17 AM   #3
KrazyZenki
Thanks alot Led Zepplin. Another other opinions on it. Im staying with stock valves so it sounds like no need for 5 angle is a 3 even neccessary with stock valves?
Old 11-03-2005, 09:38 PM   #4
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
i used to work at an automotive machine shop and when we did a regular valve job we almost always did a three angle. 30-45-60 grind. not for performance but rather to make a better seat with the valve and have a smooth flow. then agian some shops cut corners and only do a 45 deg. grind. i personally don't think it will really make that big of a difference between a three and five angle job. if you need/want that much flow get bigger valves then get a five angle.
sncs14 is offline   Reply With Quote
Old 11-04-2005, 07:19 AM   #5
Romeyo07
Romeyo07 is an unknown quantity at this point
Send a message via AIM to Romeyo07 Send a message via MSN to Romeyo07 Send a message via Yahoo to Romeyo07
valve jobs are like 35 bux anyway. It's not a "better safe than sorry" scenario, but I say do it for the price and whatever gain you might get out of it.
Romeyo07 is offline   Reply With Quote
