![]() Join Date: Jun 2003
Name this part on an SR20
Can anyone tell me what this part is and its purpose. Its located on the tranny. Im installing an SR20 into a datsun and im seeing if i can get away with taking this thing off for its getting in the way.
thanks alot! ![]() |
Speed sensor. There should be one 10mm bolt bolting it to the trans.
thanks. i new it was a sensor of some sort. are there other alternatives to reading the speed? just in case, is their any tranny oil thats gonna spill out if i take it off?
I'm not aware of any other way to read speed.
Yes, I believe trans fluid will come out. |
get s15 trans and rear end.
S15s have the speed sensor in the rear end plus you get the 6speed goodness. Bad news: They are not cheap.
92 FastBack - Project 98 SE - Daily Driver |
#7 | |
![]() Join Date: Mar 2002
![]() Feedback Score: 9 reviews
Don't make things more difficult they need to be.
Plenty of SRs have been put into dimes with no problems whatsoever.
![]() Join Date: Apr 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
try fitting an SR bellhousing on a CA18ET/CA20E s12 200sx box. If you can, get an 1986-88 transmission (stronger than the 84-85 ones). Its a much smaller tranny, but it'll take s13 bellhousings. I run a KA24 in my s12, and all that I did was swap the s13 bellhousing onto the smaller CA20E tranny. It also uses a mechanical/cable speed sensor that is smaller than the electronic one that s13's use.
#10 | |
oh you're putting it into a roadster? nice.
I've seen a few SR20DEs go into those.
