Old 11-01-2005, 05:25 PM   #1
Krinkov
Krinkov's Avatar
Krinkov will become famous soon enoughKrinkov will become famous soon enoughKrinkov will become famous soon enoughKrinkov will become famous soon enoughKrinkov will become famous soon enough
Check out my new BIG BRAKES!! anyone else do this yet???
stock rear.
Sti rear Brembo with EVO rear rotor
and it BOLTS RIGHT UP!! it needs a 3mm spacer here for the correct offset, you need to trim/remove the dust cover thats all, the brembo brake line even screws right in!
For comparison.
I have the fronts going on too, but I need to machine a couple brackets, I had an extra set of the gold STI brembos, but Im close to certain the red EVO brembo calipers use the same bolt spacing. EVO take-off Brembos are pretty cheap, either from wreck part-outs or people upgrading, theres not a big market to sell them since all other EVO guys already have brembos so Ive seen whole sets front and rear sell for around $600! Im making a few sets of front brackets, let me know if anyone wants any
Krinkov is offline   Reply With Quote
Old 11-01-2005, 05:28 PM   #2
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
What you gonna do for ebrake?
rancid240 is offline   Reply With Quote
Old 11-01-2005, 05:44 PM   #3
Krinkov
Krinkov's Avatar
gonna make a bracket to run a secondary wilwood cable E-brake caliper like the Ferraris do.
until then guess I'll be parking in gear like alot of the guys with Z32 rear swaps do that dont swap over the drum brake
Old 11-02-2005, 07:56 AM   #4
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
It seems like this company is way ahead of you...
http://arizonazcar.com/240sxbrakes.html
BigVinnie is offline   Reply With Quote
Old 11-02-2005, 08:35 AM   #5
projectRDM
projectRDM's Avatar
That has nothing to do with what he has planned. His idea was to use Wilwoods strictly as a secondary caliper for the ebrake, not the replace the OE caliper.
FORMERLY R240NA
Old 11-02-2005, 08:53 AM   #6
BigVinnie
BigVinnie's Avatar
My bad didn't notice he was going to use it for strictly E-Braking.......
Old 01-11-2007, 11:55 PM   #7
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
take a look on the Jag XK8 supercharged car on the rear and also on the galardo lambo they also have an E-brake caliper.
racer98 is offline   Reply With Quote
Old 09-26-2009, 09:32 PM   #8
STR8E180
STR8E180 is an unknown quantity at this point
u can just use ur standard caliper as a ebrake it works fine
STR8E180 is offline   Reply With Quote
Old 09-29-2009, 01:01 AM   #9
Krinkov
Krinkov's Avatar
also as I posted (buried) earlier, the rear EVO rotors have the EXACT same diameter as the stock Z33 Ebrake hardware so the Z33 ebrakes should work in the rear exactly the same if you were doing a regular Z33 rear brake swap. Would be great if someone would do this to confirm!
Old 11-01-2005, 05:46 PM   #10
THX1138
THX1138 is an unknown quantity at this point
More importantly, how do you plan to bleed them? Unless you're gonna put the car on a rotisserie to bleed the brakes, make sure you switch those things side-to-side before you put it on the road.
Good call on the Wilwood spot caliper. I'm almost definitely gonna go that route whenever I get around to upgrading the rear brakes.
THX1138 is offline   Reply With Quote
Old 11-01-2005, 06:33 PM   #11
Krinkov
Krinkov's Avatar
haha, these are just a mock up, only had the one caliper handy today but yes I have the right ones for the right sides, no point in running big rear brakes and stock front brakes untill I get the fronts installed
Old 08-17-2012, 03:19 PM   #12
blessedhellrider
blessedhellrider's Avatar
blessedhellrider is an unknown quantity at this point
very observant.
blessedhellrider is offline   Reply With Quote
Old 11-01-2005, 05:48 PM   #13
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
umm wat about the front?
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 11-01-2005, 06:03 PM   #14
A Spec Products
A Spec Products's Avatar
very cool
i was gonna do this with a set of evo 8 brakes we have here, but never had time
keep us updated, thats nice, STI x EVO combined
is it installed upside down, i thought u need to install the bleeder facing up?
A SPEC PRODUCTS CORP
Old 11-01-2005, 06:34 PM   #15
Krinkov
Krinkov's Avatar
umm did you even read the post?
Old 11-01-2005, 07:30 PM   #16
WILDACEX187
wat i tried to say is that why wont u get a weird brake balance if u have such big brakes in the rear and stock front? wat kind of master cylinder will u use?
Old 11-01-2005, 07:53 PM   #17
aznpoopy
aznpoopy's Avatar
he said it in the first post
interesting swap. its nice to know we have yet another option.
Old 11-01-2005, 07:56 PM   #18
black s13
black s13's Avatar
black s13 is an unknown quantity at this point
Send a message via AIM to black s13 Send a message via Yahoo to black s13
so you really didnt read the post?
he went over it at least twice.
props, looks good. i was working on my friends STi this evening and wondered how difficult it would be to swap the brakes.
black s13 is offline   Reply With Quote
Old 11-01-2005, 06:06 PM   #19
OptionZero
OptionZero's Avatar
Cool, are STI/EVO brakes identical?
Because i'd have thought that 5x100 bolt pattern would have been a deterrant, but hey cool.
Still alot of work since there's no provision for e-brake, but if you want the bling, it's impressive.
OptionZero is offline   Reply With Quote
Old 11-01-2005, 06:37 PM   #20
Krinkov
Krinkov's Avatar
you think having big brakes is is just for "bling"
and yes, you cant run the 04STI rotors since they are 5X100, the 05+ STI run the 5X114 but I dont know what the offset of those are, might get a set of those too to play around with, I'll keep this updated
Old 11-01-2005, 07:43 PM   #21
SirWarrior
SirWarrior is an unknown quantity at this point
Nice write up.
But I already went the Z32 route and my S14 came with Z32s already on them.
But its good to see someone out there is actually thinking outside the box
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 11-01-2005, 08:13 PM   #22
Krinkov
Krinkov's Avatar
Originally Posted by SirWarrior
Nice write up.
thanks, this inst quite a "write up" just yet, just excited and thought I would post this first, I'll probably do a full write up when I get the fronts sorted and figure out what Im going to do for an E-brake. I was looking at front/rear Z32s to begin with but if all goes well I might be able to pull this off for close to what you could usually find Z32 front/rears for, and since both my other two cars run these same Brembos, Im a bit partial to them
Old 11-01-2005, 07:55 PM   #23
kingsol
kingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enoughkingsol will become famous soon enough
Send a message via AIM to kingsol
props for trying something new. can't wait till everything is figured out.
There is a time in every man's education when he arrives at the conviction that envy is ignorance; that imitation is suicide; that he must take himself for better for worse as his portion; that though the wide universe is full of good, no kernel of nourishing corn can come to him but through his toil bestowed on that plot of ground which is given to him to till.
-Emerson
kingsol is offline   Reply With Quote
Old 11-01-2005, 08:37 PM   #24
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
*subscribes*
wow, good to know.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
Old 11-02-2005, 12:16 AM   #25
NZO
NZO's Avatar
NZO is an unknown quantity at this point
Send a message via AIM to NZO
Uh oh Jeremy is into nissans now. Dangerous...
sentinelguild.com/nzo/PFCDB/
NZO is offline   Reply With Quote
Old 11-02-2005, 12:21 AM   #26
DP_Michelle G
DP_Michelle G's Avatar
DP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really nice
very nice keep us updated
Last edited by DP_Michelle G; 11-02-2005 at 12:22 AM.. Reason: i can't spell for shit tonite sleepie
DP_Michelle G is offline   Reply With Quote
Old 11-02-2005, 11:15 AM   #27
Krinkov
Krinkov's Avatar
LOL, thought I would find you over here!
I'll still keep a flying Subaru or two though, lol
Old 11-14-2005, 10:57 AM   #28
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
Jeremy, you're funny hopping your suby off the ground. I wasn't for sure if you were going to post it on here since you did on iclub. So now you have me thinking off putting these on now...
TIA
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 11-02-2005, 01:11 AM   #29
Supreme
Supreme's Avatar
Supreme is an unknown quantity at this point
Send a message via AIM to Supreme
Other than the bolt pattern of the 04 sti, evo/sti brembos are the same. Only thing is EVO brembos are easier to find, the sti brembos sell FAST to ej20 owners. They both use the same exact pads with 4 pot front/2 pot rear.
Signature Exceeds Forum Limits
Supreme is offline   Reply With Quote
Old 11-02-2005, 02:15 AM   #30
Krinkov
Krinkov's Avatar
well they are very close but there are slight differences,
EVO rotors
Front = 320mm
Rear = 300mm
STI
Front = 326mm
Rear = 316mm
another interesting note is that the EVO front rotors are 32mm wide whereas the STI fronts are 30mm wide. They use the same Brembo caliper but the EVO actually uses 1mm skinnier brake pads! so you can use EVO pads on STI and just be short a bit of pad life(Ive dont this on my STI) but you cant use STI pads on an EVO unless you turn the rotors down 2mm. Some companies, Like EBC, only make one part number for EVO and STI pads and just cheat STI guys out of 1mm on each pad, lol.
One other difference in the fronts, besides the diameter, is the hat height(offset) the STI(53mm) is almost identical to the 300ZX(54mm) whereas the EVO is 43.5mm. Since Im designing custom brackets anyways, I can make them to whatever offseet they need to be to fit, though all things being equal, the EVO rotors will move the Brembo caliper about 10mm closer to the wheel than the STI or Z32 rotors, so that could be a clearance problem depending on what wheel your running, the best combo might be EVO rear rotors and 05+ STI(%X114) front calipers to keep the offset as close to stock as possible, and they're 6mm bigger to boot!
