Old 11-01-2005, 09:48 PM   #1
240silvia
240silvia's Avatar
240silvia is an unknown quantity at this point
Send a message via AIM to 240silvia
How do you drain the Power Steering Fluid?
What's the best way to drain the fluid, without making a huge mess???? I searched and found nothing!
-Chares
240silvia is offline   Reply With Quote
Old 11-01-2005, 11:52 PM   #2
OdessaS13
OdessaS13's Avatar
OdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the rough
Send a message via ICQ to OdessaS13
take it to a mechanic, thell make a big mess, u just wont have to care
but seriusly, i tried searching for u so i can say " u didnt search hard enough" but this is the closest i found
http://www.autozone.com/servlet/UiBr...3d80180ede.jsp
OdessaS13 is offline   Reply With Quote
Old 11-02-2005, 03:31 PM   #3
240silvia
240silvia's Avatar
I searched on here, not on the damn autozone site. And no, I'm not going to take it to a mechanic to drain some fluid, that's just plain stupid. And I don't need to know how to take the pump off. I just didn't know if there was a way to get the fluid out of the pump without making a huge mess, but, I guess i don't have any other option.
Old 11-02-2005, 03:41 PM   #4
Al_S14
Al_S14's Avatar
Al_S14 is an unknown quantity at this point
Send a message via AIM to Al_S14 Send a message via MSN to Al_S14
you cant just drain the fluid out of a rack there is no drain plug. there is also no service interval for ps fluid its not meant to be "drained". take it to a dealer or some other shop and ask for a Power stearing flush. its main purpose is to replace old fluid and it will not make any kind of mess.
Al_S14 is offline   Reply With Quote
Old 11-02-2005, 03:59 PM   #5
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
to drain it:
remove the feed line to the pump from the reservoir, and drain into a container
remove the belt and pressure line from the pump and spin the pump, pumping the fluid into a container
remove the return line from the rack to the reservoir from the rack, crank steering back & forth, forcing fluid out into a container
Be warned, it is sometimes difficult to bleed the system after this.
This works much easier, and if done correctly gets requires no bleeding. Most machines only can do a 98% flush, this will do just as well.
To flush it the poor man's way, remove the return line from the rack to the reservoir from the reservoir and point it into a container. Put a funnel into the reservoir, have about a gallon of fluid on hand in a container that pours easy (old coolant jug works). Have a friend start the car and crank the wheel lock to lock as you pour fluid into the reservoir. Watch the level carefully, and shut the car off before you run out. Also watch the fluid comming out of the return line to see if it comes out clean.
ASE Master Technician
krustindumm is offline   Reply With Quote
