Old 11-04-2005, 01:01 PM   #1
heartcooksmouse
heartcooksmouse's Avatar
heartcooksmouse is on the path to ruinheartcooksmouse is on the path to ruinheartcooksmouse is on the path to ruin
Send a message via AIM to heartcooksmouse
wtf, i'm confused. help
so far, i've searched left and right.
i've only found like four things to help reduce understear.
1) lsd/wedlocd stuff, but i'm not worried about that.
2) remove front strut bar (i don't have one)
3) wider front tyres and lower profile with wider rim size.. yadi ya
4) front and read toe in
5) basic allignment options
ok, i ment 5.
are those seriously the only things you can do?
every search i've made has only turned up those tips.
nothing much on suspension besides the sway bar.
right now i've got a '91 Coupe with KYB AGX's and eibach sportline springs, tanabe spacers/collars, and falken ziexs. fronts aren't in the best of condition.
heartcooksmouse is offline   Reply With Quote
Old 11-04-2005, 01:04 PM   #2
240SeXy!
240SeXy!'s Avatar
240SeXy! is making his/her stupidity well-known240SeXy! is making his/her stupidity well-known240SeXy! is making his/her stupidity well-known240SeXy! is making his/her stupidity well-known240SeXy! is making his/her stupidity well-known
^ well and i ggueesss Tire choice..
240SeXy! is offline   Reply With Quote
Old 11-04-2005, 01:05 PM   #3
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Those tires suck. The biggest mod you can do for your car is tires. Get some R-Compounds for the front. I have a very similar set up to yours.
Old 11-04-2005, 01:32 PM   #4
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
fattier rear sway bar...
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 11-04-2005, 01:40 PM   #5
heartcooksmouse
cool, so those are really the only things you can do huh?
yeah, i don't like those tyres. i guess for the back they would be ok right?
i mean... if i drift them who cares how grippy they would be?
and by "fattie" how fattie do you mean?
thanks all.
Old 11-04-2005, 01:55 PM   #6
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
http://www.zilvia.net/f/showthread.php?t=46093
Pepperoni is offline   Reply With Quote
Old 11-04-2005, 02:23 PM   #7
OptionZero
OptionZero's Avatar
drifting isn't about purposely not having grip; it's about having grip and purposely breaking it...
Get better tires, a Kumho MX or a Hankook RS Z212 ..cheap with many sizes, do not stagger much if at all front/rear sizing.
Remember what understeer is, conceptually: When the front end has less traction or loses traction before the rear.
The Solution?
Add grip in front or reduce grip in back.
The stiffer end of the car loses grip first, which is why a stiffer rear end (Sway bar, stiffer coilover setting, strut bar) will make the rear come out first; and why a stiffer from will make the front plow.
I'm assuming you're a pretty novice driver, so before investing in massive modifications to make an instant-spinout type car, i'd just go with better tires (and if need be, wheels), and drive more to build your skill at breaking them loose. Drifting isn't all power-over, afterall...but hey, i dont know anything about drifting.
Old 11-04-2005, 04:17 PM   #8
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
weldlocd will GIVE you understeer
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 11-04-2005, 07:34 PM   #9
heartcooksmouse
yeah, i know the weldlocd will give you more. i wasn't planning on bothering with that. i want to be able to actually turn into a corner without plowing forward.
i'm deffenately getting tires, so, first step there. then yeah, stiffen the rear. and whatever... play it how it goes.
except right now i got another problem to deal with.
thanks for all the tips.
as for that link, i never found that one, now it seems that guy who asked it is a pro about LSD's.
Old 11-04-2005, 06:15 PM   #10
Nan Desu Ka?!
Nan Desu Ka?!'s Avatar
Nan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to allNan Desu Ka?! is a name known to all
Send a message via AIM to Nan Desu Ka?!
on entry yes, but with some throttle/weight dist. you can get it to oversteer very nicely.
get a rear sway/strut/cpillar bar, preferable all of the above. better tires. lower tire pressure in the front, higher in the rear. basically make it so the rear is as stiff as possible, that way it will be easier to oversteer and get the rear to break traction.
i noticed a huge difference once i made a c-pillar bar for my hatch outta some thick ass steel tubing.
Norcal-240sx.net
Nan Desu Ka?! is offline   Reply With Quote
Old 11-04-2005, 07:01 PM   #11
EchoOfSilence
really, now? details?
Old 11-04-2005, 06:45 PM   #12
sw20>>s14
sw20>>s14's Avatar
dont just make the rear crazy stiff and leave the front naked...dont forget that a lot of front end parts/braces dramatically help turn in also...unless if your talking solely about drifting...in which case you should state...
if your talking about drift then either listen to these guys and learn with what you have or set your car up leaning towards oversteer...meaning stiff ass rear, very little tow in up front and toe out in the rear, set caster to max...play around with different settings...its all preference...
sw20>>s14 is offline   Reply With Quote
Old 11-04-2005, 07:30 PM   #13
Sil Beer S13
Sil Beer S13's Avatar
Sil Beer S13 is on a distinguished road
Send a message via AIM to Sil Beer S13
learn how to spell
maybe its DRIVER ERROR not the car.
get an alignment, get better tires welded diffs suck
its super understeer followed by horrible oversteer.
Sil Beer S13 is offline   Reply With Quote
