Old 11-05-2005, 01:37 AM   #1
john891
john891 is an unknown quantity at this point
neww gt2871r setup runs TERRBILE.
hey guys, I just got my enthalpy tuned ECU back in today and attempted to get her running by tonight..
after the injectors leaking becasue I forgot to put in the stock O-rings, the car fired right up. Although the car runs, it runs like crap.
set-up: GT2871R
z32 MAF
sard 550's
enthalpy tuned ECU
the car has the symptoms of a bad MAF. Idles bad, and doesnt rev smooth. When I unplug the the maf It runs the same as when it is plugged in. I have tried rewiring it twice and still nothing.
Also, A LOT of gray/black smoke it comming from the exhaust... this has me worried. Could it be becasue the car is runnng so rich becasue of the MAF?
The boost guage reads about 18-17 of VAC. Im used to it being about 20 with the stock turbo, could there be a boost leak?
After tryign to rewire the MAF and fix possible boost leaks I started the car and it was still the same, smoke pouring from the exhaust. When I put my hand infront of the muffer I got a black liquid residue on all over it. UNBURNT FUEL?
ANY help would be appreciated, as I have searched relentlessly.
Image exceeds forum limits of 400wide x 200 high.
gold 89' SR'd coupe w/ silvia front
john891 is offline   Reply With Quote
Old 11-05-2005, 02:30 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Yups ur running rich. Hope you have a safc to lean it out a bit. In my case it was alot...I just borrowed a wide band and i was between 9-10 A/F under boost *which explains my 16mpg mileage* Leaned it out to bout 11.5 and made a day/night difference.
This on GT2871 .64 trim, 740cc, enthalpy rom tune, z-maf
CLICK HERE!!!
Old 11-05-2005, 02:44 AM   #3
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
why dont you just email enthalpy??
driftingisgay.com
nrg is offline   Reply With Quote
Old 11-05-2005, 03:25 AM   #4
speeddreamz
speeddreamz's Avatar
speeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nicespeeddreamz is just really nice
Send a message via AIM to speeddreamz
Have to agree on that, enthalpy is the man, maybe theres something about your setup thats not working right ? or is abnormal than what he is tuning for.
speeddreamz is offline   Reply With Quote
Old 11-05-2005, 04:10 AM   #5
RYAN_S-14
RYAN_S-14's Avatar
RYAN_S-14 is an unknown quantity at this point
Send a message via AIM to RYAN_S-14
see if any of your boys have a z32 maf you can borrow for a little while to check of the maf is bad or not.
agree with the peope above and email or call enthalpy
RYAN_S-14 is offline   Reply With Quote
Old 11-05-2005, 08:28 AM   #6
BaliLover
BaliLover is an unknown quantity at this point
Sounds like a leaky injector O-ring to me. I had the same problem, I managed to make a small tear in 3 out of 4 orings when putting them on. Make sure its not an injector problem. with the car running, unplug each injector, 1 at a time, and if the behavior of the car doesn't change, then you have an injector problem. Each injector that you unplug that DOES make a difference is good, and each injector that you inplug and doesn't make a difference probably has a leaky oring
BaliLover is offline   Reply With Quote
Old 11-05-2005, 10:40 AM   #7
HIGHMILEHATCH
HIGHMILEHATCH's Avatar
HIGHMILEHATCH is on a distinguished road
Exactly. I had this happen to an SR before and there was a nice puddle of fuel in the cylinder.
HIGHMILEHATCH is offline   Reply With Quote
