Old 11-14-2005, 03:18 PM   #1
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
Strange Clutch MC/SC Problems
This problem all started when my clutch master cylinder started leaking. I fixed that by rebuilding it. New cylinder, springs, seals, etc. That fixed the leak but it created a new problem. My clutch engaugement would be set at the middle, but after driving a few miles, it would slowly end up being at the very top of the peddle. Making the peddle feel very stiff (like pushing 60lb ft torque); also like an on and off switch. I took it all apart and notice the push rod was bent. A new rod fixed that. This did fix alittle of my problems. Every morning I would get into my car and notice that the peddle feel is back to normal. engaugement is in the middle. But the problem comes back the more I drive. I bought a new slave cylinder with an SS line from a member on this forum. Thought this would fix it but I was wrong. Then I went out and bought a brand new Clutch master cylinder. Thought it fixed it. 3 days with no problems and now today; I'm back to square one.
Also, when i leave my car idle. the clutch engaugement ends up disaparing off the peddle. I really hope this isn't a bent clutch fork or something where i have to drop the tranny. =\
an hr ago, i was stuck on the side of the road bleeding my lines; because the engaugement disapared.
edit: took a look at everything. removed the stupid loop on my lines. gravity bleed then pump bleeding (3 pumps then hold, bleed). I also let the car idle for like 10mins, the clutch engaugement stayed the same.
We'll see how well this fixed the problem by tonight.
edit2: After driving the car around (40 miles streets). The clutch seems to be working like normal. But I can feel something strange on the engaugement. Hope it's not a bad pressure plate. =X
driftingisgay.com
nrg is offline   Reply With Quote
Old 11-21-2005, 07:52 AM   #2
91s13240sx
91s13240sx is an unknown quantity at this point
hey im having the same problem right now when you say you removed the loop are you talking about the clutch dampener mounted on the frame
91s13240sx is offline   Reply With Quote
Old 11-27-2005, 05:15 PM   #3
nrg
yes, that cluch dampener. removed it, bleed it and it's fine now.
driftingisgay.com
