Old 11-29-2005, 06:55 PM   #1
RiversideS13
RiversideS13's Avatar
RiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond repute
Send a message via AIM to RiversideS13
Does this sounds like BS to you?
ok....I was arguing with someone about this for a long time. I thought those figures are not reasonable....
Scion TC stock motor would lay down about 142 whp. so this turbo kit claimed it will get 290whp/331 torque with 10 psi with stock internal (9.6:1 comprssion). is it possible?
http://www.racingsolution.com/review...Read&Part=1221
RiversideS13 is offline   Reply With Quote
Old 11-29-2005, 06:57 PM   #2
go240
go240 is on a distinguished road
seems a little high
go240 is offline   Reply With Quote
Old 11-29-2005, 07:35 PM   #3
HyperTek
* Performance gains may vary based on modifications done to car
I doubt it will pull that much without internal work... But I think the list of parts would be capable of producing that.. I never drove a fast front wheel drive so Id think that would be scary understeer.
Keep it Classy
Old 11-29-2005, 08:11 PM   #4
RiversideS13
here 230 whp at 6 psi with 16G turbo??
http://www.zeropointindustries.net/s...81f6a2164a8904
10psi for 300whp
here is the dyno chart,
Old 11-29-2005, 08:14 PM   #5
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
hurray for camry power!!!
Life is good in the bay.
Eternal_240Sx is offline   Reply With Quote
Old 11-29-2005, 08:16 PM   #6
Phlip
Yes, I look like that
Phlip's Avatar
How about this, what are similarly tuned KA-T engines putting to the wheels, given their (reasonably) similar stock outputs?
Weirdo
And I write too!
Old 11-29-2005, 09:02 PM   #7
ranisron
ranisron is making a name for him/her selfranisron is making a name for him/her self
Send a message via AIM to ranisron
around the same line philip is on...
check out some of the dyno results from the FWD KA-T (Altima) guys at altimas.net. Let me go there and take a peek. then we could assume that we are comparing apples to apples (well, sort of)
EDIT: found some links... but there's no perfect match as far as on stock internals (on U13 1st Gen Altima) pushing put that much of power wtf... camry engine on crack??
I always thought drivetrain loss is more in RWD cars ... guess it's not the case anymore (after looking at some posts and dyno charts on U13)
U13 and S13
zilvia members are friendly
ranisron is offline   Reply With Quote
Old 11-30-2005, 02:03 PM   #8
RiversideS13
perhap vvti made some difference? i mean ka24de is the technology from 14 years ago and the 2azfe suppose to be the newest technology release from toyota?
here is some tech info about the motor
http://www.sae.org/automag/techbriefs_07-00/05.htm
Old 11-30-2005, 07:25 AM   #9
Angel
Angel is making a name for him/her selfAngel is making a name for him/her selfAngel is making a name for him/her self
Seems a bit high. Usually you can assume that for every 1 atmo that you run you should increase by close to 100%, so if you were making 150 whp na and boost to 14-15 psi you should be close to 300.... unless they eliminated some signifigant restrictions or did some other breathing mods.
S13 redtop 2871R.64 377 rwhp 322 rwtq
11.5 @ 117
Angel is offline   Reply With Quote
Old 11-30-2005, 02:01 PM   #10
santacruisin
santacruisin is an unknown quantity at this point
In the summertime there was an issue of modified mag with a turbo'd tc. It was makin 400sumthin horsepower on stock internals. The shop that built the tc was really surprised how much boost the engine could take with stock internals. They said they were gonna keep uppin the boost until it blew up to see just how much it would take. ALthough the tc will support crazy numbers on the stock engine it most likely will not do it for very long.
santacruisin is offline   Reply With Quote
Old 11-30-2005, 02:05 PM   #11
RiversideS13
I understand that the tc motor can handle boost well but i just think with 10psi for 290whp is too much..... 250whp would be a reasonable number
