Old 11-30-2005, 12:06 AM   #1
Rickrak77
Rickrak77 is an unknown quantity at this point
Red line for a KA?
The KA Midget is back.
The pickup I got my KA out of didn't have a tach in it, so I'd really like to know what the red line for a stock KA is since I finally got a tach for it.
How do you post pics here? I've got some pics of my car I'd like to post.
Some days you're the windshield..... Some days you're the bug.....
Rickrak77 is offline   Reply With Quote
Old 11-30-2005, 12:32 AM   #2
reefer1114
reefer1114 is an unknown quantity at this point
Search Son!
reefer1114 is offline   Reply With Quote
Old 11-30-2005, 07:47 AM   #3
orion::S14
orion::S14's Avatar
S13 or S14 KA?
Useful redline depends on which motors (different cams)...but use ~6500 as a safe redline for now...although ~7000rpm is no big deal. That's not to say you'll be making power up there, but it won't fly apart due to exessive piston speeds.
- Brian
www.KA24DEvelopment.com
Old 11-30-2005, 08:31 AM   #4
SirWarrior
SirWarrior is an unknown quantity at this point
Originally Posted by orion::S14
S13 or S14 KA?
Nissan Hardbody Pickup as stated
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 11-30-2005, 08:58 AM   #5
orion::S14
orion::S14's Avatar
OK, I'll assume a late model Frontier? Maybe a D21? SOHC or DOHC?
Nonetheless, truck cam(s?) will be geared for low end, so use ~6000rpm as a good redline.
The bottom end of all the KA's are quite similar, and that's what really limits RPM...but for your purposes, 6k is safe, and you'll most likely not make power above that...so why push further?
- Brian
Old 11-30-2005, 09:22 AM   #6
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
there is absolutly no reason to take that motor over 5600, If you look at a dyno sheet you will see that power peaks and drops off after that. There is no need to rev the piss out of a KA, it just makes more noise.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 11-30-2005, 09:30 AM   #7
Evil98silvia
Evil98silvia is an unknown quantity at this point
Send a message via AIM to Evil98silvia
Youll hit the limiter right around 7200. If your sliding your car around you will definatly need to rev past 5600.
Robbie C.
KA-T
Evil98silvia is offline   Reply With Quote
Old 11-30-2005, 10:35 AM   #8
S14DB
AFC #1
S14DB's Avatar
I hit the limiter at 6400 on the dyno.
Old 11-30-2005, 10:45 AM   #9
s14unimog
s14unimog's Avatar
Trader Rating: (22)
mine hits 6400 limiter also
Old 11-30-2005, 11:28 AM   #10
Evil98silvia
Oops sorry I have a JWT ecu. I forgot I had them move the limiter, its been a few years.
Robbie C.
KA-T
Old 11-30-2005, 04:28 PM   #11
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
When accelerating in 1st gear it is useful to take it up to redline so when you shift you are still in the power band...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 11-30-2005, 08:12 PM   #12
Rickrak77
Cool, my wife rolled the pickup (90 model, sohc in case anyone's interested) so I stuffed the whole drivetrain into a MG Midget (I started out with just the engine and tranny but the midget rearend only lasted about a week before giving up all of it's gear teeth).
I'm not sure if the 240 and the pickup used the same trans. or even rear end gears, but knowing a general redline helps.
The cam in this is definitely made for lower RPMs, it makes power to about 5600 or so, then kinda falls off, but in a 1600 pound car it doesn't matter all that much.
Old 12-01-2005, 01:13 PM   #13
socal240sx
socal240sx is an unknown quantity at this point
Send a message via AIM to socal240sx
No need to rev a KA above 5600 rpm as this the KA makes most of its power and torque lower in the RPM range (which what I like about the KA) and is a VERY durable engine at low revs because it is a light truck engine. The downside is that revving to high too much may throw a connecting rod as that seems to be the KA achilles heel from what I hear from downs that have done multiple rebuilds on their KA's
Mike F
Lake Forest CA
1990 240SX SE fastback (RPS13) KA24E
socal240sx is offline   Reply With Quote
Old 12-01-2005, 01:16 PM   #14
Evil98silvia
True if your just accelerating, but there are times where youll need to rev past. I havnt thrown a rod yet... But when I do I hope it punches a BIG hole.
Robbie C.
KA-T
Old 12-01-2005, 05:54 PM   #15
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
i think s13's have a higer rev limiter than s14's, but my 91 with a jwt is at 7200, when i bounce the rev limiter i think it would proablly go higher. but i have intake header ecu, used to have cams, etc.
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 12-01-2005, 09:16 PM   #16
Ghettokracker71
Ghettokracker71's Avatar
Ghettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enoughGhettokracker71 will become famous soon enough
Send a message via AIM to Ghettokracker71 Send a message via Yahoo to Ghettokracker71
gotta post pics and more detailed specs on the mG! I remeber back when you first starting posting about it. Thats so hot man.LIGHT fucking car with a torquey ass 4 banger...
Ghettokracker71 is offline   Reply With Quote
