Old 12-13-2005, 02:26 PM   #1
xagna
xagna has a little shameless behavior in the past
How to put new tie rod and tie rod ends?
Got tein tie rod and tie rod ends. Now I have to get the stock ones from steering rack. I was told to hammer them out but since I plan to change the steering rack in the spring, I need to know how to seperate the tie rod and tie rod ends without damaging them so that I could preserve these tein ones in the future swap.
If any one has done it, how did you take your old tie rod and tie rod end from steering rack without damaging them? I am searching but if you could tell me your experience, would appreciate a lot.
xagna is offline   Reply With Quote
Old 12-13-2005, 02:44 PM   #2
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
Lefty loosy, righty tighty....Seriously.
To get the outer out use a 3lb hammer. One good blow and it COMES! out
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 12-13-2005, 03:35 PM   #3
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
The tierod end removal from the knuckle is easy. Take the bolt off, but left it still screwed on. Bang the knuckle with the hammer, and it should pop right out. If not, try again.
Then for the rodm you've got to pry off the square plate, and use a vice to undo it out of the rack. And then you're done!
SochBAT is offline   Reply With Quote
Old 12-13-2005, 06:38 PM   #4
xagna
Wanted to know if there is another process that doesn't involve hammering.... Looks like there isn't.
Thanks Zar for the tutorial too.
Old 12-13-2005, 03:58 PM   #5
Dousan_PG
Dousan_PG's Avatar
i did a big ol write up on this back in the day..
Aaron
Pink GodziRa
Old 12-13-2005, 04:09 PM   #6
!Zar!
!Zar!'s Avatar
http://www.zilvia.net/f/showthread.php?t=27115
Old 12-13-2005, 04:15 PM   #7
mrmephistopheles
mrmephistopheles's Avatar
just mail them to me - i'll install them for you.
Originally Posted by PHLIP
Old 12-13-2005, 06:49 PM   #8
!Zar!
!Zar!'s Avatar
Don't thank me, I simply found it. Thank the great Dousan for explaining and showing it.
