Old 12-17-2005, 03:52 PM   #1
blue109
blue109's Avatar
blue109 is an unknown quantity at this point
exhaust studs broke
so, has anyone had any luck with a easy-out on a cyl. head(ex mani side) i have 3 broke and im trying to avoid pulling the head. there is plenty of room, ive just heard of the easy-out breaking and making it worse. TIA
The fire and ice combination
adjourns fresh
I return with the last
living specimen caress
when the earth is vacated
and the populous cleared
ill be the last starfighter
sipping a goblet of my tears
blue109 is offline   Reply With Quote
Old 12-17-2005, 04:02 PM   #2
aznpoopy
aznpoopy's Avatar
i tried using an easy-out on a broken coolant bleeder screw on the upper intake plenum... after a good amount of cursing and more then one broken easey out i ended up using another intake plenum i had.
you might have more luck. the exhaust studs are alot larger then the tiny ass coolant bleeder screw.
Old 12-17-2005, 04:20 PM   #3
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
easy out works like half the time... usually when the easy out breaks inside the bolt then ur definetly owned... if the studs are still external and visible and u can get a vise grip on it... do that and smack it with a hammer.. that would definely fix it... other then that youd have to drill it out and heli-coil it..
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 12-17-2005, 10:40 PM   #4
pr240sx
pr240sx is an unknown quantity at this point
use a good metal drill bit
Use good easyouts for the correct size (I used craftsman 52152 size m10-3/8)
Use a steady hand and a good drill
Use the easy outs with easy and slowly.
Heat and some PB Blast or WD 40 will help too!!
Dont break the bit nor the easyout.
A variable/reversible drill will work great.
Drill a small hole on the stud with the drill, go slowly and be sure to be in the center!!. Studs are steel, the head is aluminum!!.
Then use the easyout SLOWLY and work your way until it grab the easyout.
Hints!
Have someone spraying some pen. oil while you drill. This will cool the bit and help while heating the stud.
If you need to use the torch, beware not to heat the head too much or you can warp it. Is heating, not melting the stud!!.
Good luck
pr240sx is offline   Reply With Quote
Old 12-18-2005, 02:20 PM   #5
blue109
blue109's Avatar
thanks. im hoping they wont be frozen in there. i dont know why they broke in the first place. i barely but any torque on them, and they just snapped off. the broken ends didnt have any rust on them to indicate they had been cracked. i had to snap all the DP/O2 ext. bolts to get them off to. i love old cars.
adjourns fresh
Old 12-18-2005, 02:51 PM   #6
mrmephistopheles
mrmephistopheles's Avatar
done quite a few exh side studs with easy out.
no problem.. lots of WD40.
Originally Posted by PHLIP
