Old 01-14-2006, 11:36 PM   #1
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
safc harness question
hi i just bought a used safc, im missing the female adapter part along with the wiring harness? anyone know where i can get it?
^the part on the left?
thanks
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 01-14-2006, 11:39 PM   #2
drift into a curb
drift into a curb's Avatar
drift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond reputedrift into a curb has a reputation beyond repute
You can just cut it and wire it off that end if you'd like. If not contact and apexi dealer for parts. http://www.apexi-usa.com/
Go big or go home!
drift into a curb is offline   Reply With Quote
Old 01-15-2006, 12:04 AM   #3
turbo2nr
turbo2nr's Avatar
im assuming the female apapter part just extends the wires to get it to the ecu? it looks like there is more wires in the female part after it connects with the male?
btw with wiring it did you just cut off the male adapter, extend the wires then matched it up to the correct colors using the wiring digram on the apexi website?
thanks for the help
s14 kouki ka-t
Old 01-15-2006, 12:20 AM   #4
drift into a curb
Yeah it basically allows you to disconnect it for easy removal. I didn't notice any extra wires other than the ones you don't need to use to install the device. Yes, match up the correct colors on the SAFC diagram and locate your ecu diagram and tap/splice the wires.. like RPM, MAF, TPS, etc..
Go big or go home!
Old 01-15-2006, 12:32 AM   #5
turbo2nr
turbo2nr's Avatar
just out of curoisity what wires wont you need?
s14 kouki ka-t
Old 01-15-2006, 12:36 AM   #6
drift into a curb
I'm not sitting right by my car, so I don't remember. Just look at the diagram. I'm color blind and I figured out which wires were which.
Go big or go home!
Old 01-15-2006, 12:45 AM   #7
drift into a curb
Next time just look at it.
http://www.apexi-usa.com/pdfInstallation/18.pdf
7 wires:
Red = power
Green = rpm
Gray = TPS
Brown = ground (mount closer to ecu than black says manual)
Black = ground
Yellow = Airflow signal out to ECU
White = Airflow signal into SAFC
Not used, blue, pink, orange and a few others probably.
Go big or go home!
Old 01-15-2006, 01:11 AM   #8
Andrew Bohan
the unused ones are for cars with two mafs and different kinds of mafs
Old 01-15-2006, 01:25 AM   #9
turbo2nr
turbo2nr's Avatar
thanks alot so far its been helpful.
does any one know were i can get the color codes for a 97 ka24de ecu? so i can match them up and take it form there.
it seems simple only 7 wire have to be spliced right?
thanks
s14 kouki ka-t
Old 01-16-2006, 12:40 PM   #10
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
Ask and you shall recive. this is the installation document that coame with the SAFC ANd the caution says unhook - battery terminal before installing. witch is a GREAT idea:
this is the american vehicle suppliment thet you have to search really hard for on the apexi website:
Tenchuu is offline   Reply With Quote
Old 01-16-2006, 06:08 PM   #11
turbo2nr
turbo2nr's Avatar
thanks man that helps alot!
btw that diagram the 2nd one is for a 97 ka24de powered 240sx right.
where do i put the other ground and air signal?
thanks
s14 kouki ka-t
Old 01-16-2006, 07:26 PM   #12
Tenchuu
Tenchuu's Avatar
yes the second one is for the S14 US model 240sx.
those are the only 5 wires you tap into for the KA.
the air signal is spliced in. look at the diagram. signal goes into the SAFC and back out into the ECU.
the second ground is hook up
*****AT LEAST 3 INCHES*********
behind the 1st ground
notice how i emphasize it beause it will not work right if you don't do it that way.
Old 01-16-2006, 07:34 PM   #13
turbo2nr
turbo2nr's Avatar
im a noobe at this so im still lost.....
so the second aird signal goes into the same port in the ecu as the first?
and the 2nd ground is grounded on the same line but 3" or more behind the first going in the direction towards the safc? right?
and obd1 and obd2 ecu diagram are the same?
sorry for the stupid question
s14 kouki ka-t
Old 01-16-2006, 07:55 PM   #14
Tenchuu
Tenchuu's Avatar
look on the right hand side of the diagram. notice how one says imput and the other says output? that is the kee. signal comes from you MAF into the white wite (imput) then gets edited by the SAFC and goes OUT the yellow wire (output) inot the ECU so the ECU sonly sees the edited signal.
if you can't get that you may want too look into getting someone else to help you out on this one.
and the ground it in the direction AWAY from the ECU and 3+in past the connection of thre brown wire. it's best to use T splices to put this in. (1.99 a box at napa)
Old 01-16-2006, 08:12 PM   #15
turbo2nr
turbo2nr's Avatar
i think i get it so the air press. would be some thing like this:
___ecu (maf)____ ____ ecu(box)
______________| |
______________| |
_____white(input) yellow (output)
_____________ ____
_______________^
_____________safc
right?
(dont mind white lines at far right had to use to space properly)
s14 kouki ka-t
Old 01-16-2006, 09:45 PM   #16
Tenchuu
Tenchuu's Avatar
yeah that's the basics of it. altho i thought the manual did a bit better job of drawing it.
Old 01-16-2006, 09:47 PM   #17
turbo2nr
turbo2nr's Avatar
lol thanks for all the help tenchuu. ill try it tomorrow.
s14 kouki ka-t
Old 01-16-2006, 10:30 PM   #18
Andrew Bohan
conceptually i tihnk of the mafs signal more like this:
MAFS--------SAFC-------ECU
and stock is just like this:
MAFS--------------------ECU
the safc intercepts the signal and modifies it how you want based on throttle position and rpm.
it basically lies to the ecu about how much air the mafs is reading. the ecu tells the injectors how much fuel to flow based on how much air the mafs reads, so if you modify the mafs signal, the injectors flow differently to match the signal.
